ratherb-buggin Samba Member
Joined: January 30, 2005 Posts: 997 Location: Shawnee, KS
Posted: Wed Mar 02, 2011 12:24 am Post subject: Beetle Transmission Identification? |
I looked in this: http://www.thesamba.com/vw/archives/info/bugchassisdating.php
And can't find any info on this transmission. I was trying to figure out what year is is? The number serial # is: A0034690
Above that it looks like this:
46
113-301-103
D
Any ideas? I think it's a 68 bug or KG? If I measure the axles would someone know? I'll take some pictures tomorrow. |
Dougy Dee Samba Member
Joined: August 21, 2004 Posts: 1790 Location: Niagara Region, CANADA
Posted: Thu Mar 03, 2011 12:02 pm Post subject: |
| My reference sheets suggest it is a 3.88 R&P unit from a Karman Ghia. Installed after 8/70. |
Posted: Thu Mar 03, 2011 3:53 pm Post subject: |
| That's cool. What reference sheet did you use? I was getting different numbers from different spec sheets online. |
DerekR Samba Member
Joined: July 22, 2004 Posts: 384 Location: Riverton, Utah
Posted: Thu Mar 03, 2011 4:59 pm Post subject: |
| ratherb-buggin wrote: |
I have the same question. I cant find any reference to my trans #9641947 in the vin# tech section. I think its a 67 (long axles, 5 bolt) but was wanting some confirmation.
Sorry about the hijack  _________________ 63 Ruby Red Double Cab
60 SO 23 Westfalia SWR/BG Camper
59 Dove Blue Standard Kombi |
Posted: Thu Mar 03, 2011 6:14 pm Post subject: |
Sorry. The reference sheets I have refer to the AlphaAlphaXXXXX style of trans identification numbers. The numbers only style reference I dont have.
I have 2 sheets, from different sources, that have similarities but dont share errors. |
Posted: Thu Mar 03, 2011 6:31 pm Post subject: |
| Dougy Dee, thanks a LOT for the info!! That info is priceless when you're looking for it! I appreciate the help, I really do! |
socalvws Samba Member
Posted: Sat Mar 19, 2011 9:56 pm Post subject: |
Hey Dougy Dee,
can you help me too? What about ID # AB1098869
Thanks,
Tim _________________ '68 Mexican Beetle dubbed "Bastard Bug"
'80 Rabbit Pickup
'91 Jetta GLI |
Posted: Sun Mar 20, 2011 5:14 am Post subject: |
4.375 from a 1300 car, up to 08/70
A lot of this info is available from several sources online. It often conflicts so you may have to use the dartboard method to decide who to believe. |
Posted: Sun Mar 20, 2011 10:55 am Post subject: |
Thanks Dougy Dee. _________________ '68 Mexican Beetle dubbed "Bastard Bug"
'80 Rabbit Pickup
'91 Jetta GLI |
Bruce Samba Member
Joined: May 16, 2003 Posts: 17705 Location: Left coast, Canada
Posted: Sun Mar 20, 2011 12:53 pm Post subject: |
A0034690
| Dougy Dee wrote: |
This comes up a lot. The trans code above is A, zero, zero, three....... It is not A, oh,......
So the original gearbox is not from a Ghia with a 3.88. _________________
| overheard at the portland Swap Meet... wrote: |
| ..... a steering wheel made from a mastadon tusk..... |
Posted: Tue Dec 27, 2011 3:17 pm Post subject: |
| Bruce wrote: |
A0034690
| Dougy Dee wrote: |
So the original gearbox is not from a Ghia with a 3.88. |
Interesting... I'll keep looking for info then on that one.
I also picked up a new transmission with a serial number of 9500991
The axles have straight shock mount arms like on a 67. So maybe a 67? |
md perf Samba Member
Joined: March 07, 2012 Posts: 149 Location: Pinckney, MI
Posted: Wed May 15, 2013 11:42 am Post subject: |
any chance of sharing this sheet? _________________ They've done studies, you know. 60% of the time, it works every time |
L0cksmith Samba Member
Joined: January 10, 2014 Posts: 1 Location: United States
Posted: Fri Jan 10, 2014 11:17 am Post subject: Transaxle code issue |
| I'm having the same problem I have an old swing axle and cant seem to locate the number on the list. Mine is H0162661 any ideas? I'm trying to figure out the gear ratios..... btw it's a tunnel case. I'm not sure what it came out of either, the rear suspension was given to me with transaxle included. |
Chalklinedetail Samba Member
Joined: April 25, 2010 Posts: 311 Location: San Mateo, CA
Posted: Tue Feb 25, 2014 5:41 pm Post subject: |
Can anyone help me out? I picked up a transaxle that I was told came out of a 64 Type 1, but I'm not sure. Here's the info I have
The case has the following number cast into it: 113-301-103
The number stamped on the case is: 5254276
The nose cone has the following number cast into it: 113-301-211 E with the number 7 stamped above it. Does this mean that the case and the nose cone came from two different lots?
What year did this transaxle come from?
How can I tell if I have long or short axles?
Any help would be greatly appreciated.
Adrian _________________ My 63 build thread - http://www.thesamba.com/vw/forum/viewtopic.php?t=520975&highlight= |
EverettB  Administrator
Joined: April 11, 2000 Posts: 72023 Location: Phoenix 602
aa390392 Samba Member
Posted: Wed Feb 26, 2014 1:05 pm Post subject: |
OK a lil help here...I have a 56 but after pulling the tranny I discovered NOT a split case....the # stamped on it is as follows 8654253?
And if I want to take it back to a split case what I should be aware of?
backing plates/ drums /outter bearings/em brakes????? or will it bolt back up without a problem? Thanks
Thomas _________________ .
getting grumpy & less tolerant!
55 ragtop
56 delux sedan
56 Kabriolet |
peaceful warrior Samba Member
Joined: January 22, 2005 Posts: 5271 Location: Taoswest, USA
Posted: Fri Oct 17, 2014 6:30 pm Post subject: |
Noticed the references to the Alpha number. Mind if I ask where on the tranny that number is stamped. I felt lucky to find the 34/113 301 103/E numbers on the right side of the tranny case.
Thank you.
I am trying to figure out if my transmission is a 12V OG for a late 66 or a 67 transmission. _________________ "Two things are infinite: The universe and human stupidity; and I'm not sure about the universe." Albert Einstein
"Notchboy" says "Man up!"
"Tram" says " My bus is bigger than your bus."
66 13W Deluxe, 68 Westfalia, 87 Syncro.
TOOB Member #15
Brian |
Bruce Samba Member
Posted: Sat Oct 18, 2014 2:51 am Post subject: |
filbuggy Samba Member
Posted: Mon Nov 24, 2014 5:48 pm Post subject: Need help with trans/engine id |
I've looked all over the site for a couple hours but no luck. Any help appreciated.
Vehicle in question is Manx style buggy. Registered as a 1966.
Transmission numbers
5
113 301 103
3886294
Engine numbers
F2038 back by timing belt
04 BL
FH 1601 601 A on driver side engine |
