VDO Tach 6volt How to install?
Marcello_6v
Marcello_6v is offline
PostPosted: Fri May 27, 2011 7:39 am    Post subject: VDO Tach 6volt How to install? Reply with quote
Hi! I'have this VDO Tacho (from oval beetle i think).
Uploaded with ImageShack.us
I know how to install modern 12v VDO tacho, but this has 4 "plugs"
- R ? (on left)
- G ? ( on center)
- B ? (on right)
- Ground (ok i know this one) Embarassed
Thanks!!!
Nel dubbio...accelera!
Harris
Harris is offline
PostPosted: Fri May 27, 2011 10:40 am    Post subject: VDO 6 volt Tach Reply with quote
Marcello_6v,
The face looks correct enough for this to be an original 0-5000 tach. If so, it originally ran off of a cable on the engine pulley and a wire to the coil.
Ii can be converted, if you don't have the cable, to either 6 volt or 12 volt. Not cheap to do so however.
Please post the number and date on the back to confirm if it's what it appears to be. Can't tell from the photo.
Marcello_6v
PostPosted: Fri May 27, 2011 11:20 am    Post subject: Reply with quote
Hi Harris! Thank you! Very Happy Sorry for the bad quality of the "rear" photo!
Here another one
Date (I suppose)
3 /57
Number (I suppose)
85/1/6
I don't have any cable! Shocked Shocked So now? what is this cable for? What can I do?
Harris
Harris is offline
PostPosted: Fri May 27, 2011 11:52 am    Post subject: VDO Tach Install Reply with quote
Marcello,
Numbers are correct for an original. Not many around. North Hollywood Speedometer in California will charge around $ 150 to convert it to 6 or 12 volts--plus shipping. Check there for a good comparable instrument shop. I don't think you can wire it as it is, but could be wrong. Just don't damage it.
This is a diagram of the cable used for this tach borrowed from J. Harasen. The tach is rare and the cable even more rare.
Marcello_6v
PostPosted: Fri May 27, 2011 12:58 pm    Post subject: Reply with quote
Thanks Harris! You're so kind!! Ok, i put this one in my cabinet Laughing Wink
BulliBill
BulliBill is offline
PostPosted: Mon Nov 16, 2015 7:08 am    Post subject: Re: VDO Tach 6volt How to install? Reply with quote
My VDO 0 to 5,000rpm set up, just missing the 36hp crank pulley nut drilled with a set screw for the cable (NOS cable too)
Has anyone "made" a crank pulley nut (drilled for cable and drilled for set screw) for use with this type of cable-driven generator/sender for this tachometer? I need to find one or have one made... last piece of the puzzle and then I can put it into use on a Okrasa motor I have.
Bill
Mission VW - San Fernando
Thornton VW - Stockton
Thanks for any help!
Harris
Harris is offline
PostPosted: Mon Nov 16, 2015 2:05 pm    Post subject: Re: VDO Tach 6volt How to install? Reply with quote
Bill,
Given the cable size and nut thread which you have, I believe one could be machined by a shop. I had a special connection (oil relief nut and gauge sender thread) machinds here at a hot rod speed shop in Dallas. Worked perfectly. These young kid are smart and know how to improvise.
Vintage oval
Vintage oval is offline
PostPosted: Sun Jan 26, 2020 9:06 pm    Post subject: Re: VDO Tach 6volt How to install? Reply with quote
Marcello_6v,
Did you ever get your VDO electrical sender ( generator ) mounted on you Okrasa.
I have a NOS unit with all parts and would like to see a phot of one mounted.
Thanks
Jeff
Peter_Plade
Peter_Plade is offline
PostPosted: Mon Jan 27, 2020 11:55 am    Post subject: Re: VDO Tach 6volt How to install? Reply with quote
Hi Jeff
I have a tach like that installed in my 54 oval.
I decided to drill holes in the rear breast tin and weld in a pipe to route the cable in, think it looks better than the way shown in the original instructions.
Hope this helps you.
http://vw-bluehats.blogspot.com/
joe h.
joe h. is offline
PostPosted: Wed Feb 05, 2020 9:08 pm    Post subject: Re: VDO Tach 6volt How to install? Reply with quote
Peter_Plade wrote:
Hi Jeff
That's brilliant! I've been hesitant to mount mine because of the cable routing. I'm going to give this a shot
Thanks Peter!
http://www.cascadekombis.org/vintage-meet
Peter_Plade
PostPosted: Sun Feb 09, 2020 9:39 am    Post subject: Re: VDO Tach 6volt How to install? Reply with quote
Thanks Peter!
Thanks, let me know if ned more pics or info.
