Removing Rear Reflectors
lowdowndub
lowdowndub is offline
PostPosted: Wed Jun 22, 2011 12:42 pm    Post subject: Removing Rear Reflectors Reply with quote
I just scored a set of rear reflector seals and would like to replace the crack crappy ones I have but I'm not sure how to remove the reflector and perch to replace them.
Any help?
lowdowndub
PostPosted: Wed Jun 22, 2011 12:43 pm    Post subject: Reply with quote
I think I found it.
Do I need to remove the tail light housing to get at the bolt/nut?
chaosisme
chaosisme is offline
PostPosted: Wed Jun 22, 2011 12:50 pm    Post subject: Reply with quote
Yes.
If your old ones are still serviceable, then you might want to hit the old reflector nut/bolt with some penetrating oil or something. They always seem to be rusted up pretty good. I just replaced one on my square and I thought I was turning the nut and I ended up snapping it off.
'65 1500 S [quareback]
'68 FI Sunroof Squareback
'70 Westy
OCT3 - Orange County Type 3's
68notch
68notch is offline
PostPosted: Wed Jun 22, 2011 10:34 pm    Post subject: Reply with quote
I've snapped one of those refector studs too when try to pull one from an old panel with using any oil.
I found one of those flexi shaft (wire like) extensions and socket works perfect to reach through the rear tail light hole and around 180 degrees.
John
68 Aussie notch
2011 Citroen Berlingo
https://www.facebook.com/Fastacraft
RHD dash pad project http://www.thesamba.com/vw/forum/viewtopic.php?t=475227
Mike Fisher
Mike Fisher is offline
PostPosted: Thu Jun 23, 2011 9:11 am    Post subject: Reply with quote
I've gotten them out/in with my 1/4" drive. A flex-shaft sounds like a good addition to the setup.
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
OhHerrooo
OhHerrooo is offline
PostPosted: Thu Jun 23, 2011 9:28 am    Post subject: Reply with quote
i was able to get at it with a small adjustable crescent wrench.
'67 Squareback
'69 Squareback
'68 Westfalia
'68 Squareback
www.evenkeelsurfshapes.com
chaosisme
PostPosted: Thu Jun 23, 2011 11:09 am    Post subject: Reply with quote
I just use a 1/4 driver with a deep socket and that works fine, plenty of room.
'70 Westy
