bajafreaks Samba Member
Joined: July 17, 2007 Posts: 469 Location: gardnerville, nevada
Posted: Wed Jul 20, 2011 5:01 pm Post subject: spark plug length/reach |
78 2.0 motor. I bought some new NGK BP6ET plugs and noticed they are about a 1/8" longer than the plugs I pulled out of the motor which are Autolite 405 do I need to be concerned about the longer plug or is the autolite just short ??? |
Posted: Wed Jul 20, 2011 7:53 pm Post subject: |
The NGK's should work fine. What I would be concerned about is that the last bit of threads are going to be filled with carbon and maybe even burned a bit. Probably best to run a thread chaser into each of the threads before installing the new plugs. At the very least spray some BP Blaster or something similar down the holes to try and break up the carbon. |
Lionhart94010 Samba Member
Joined: January 04, 2005 Posts: 1418 Location: SF Bay Area / Silicon Valley / So Cal
Posted: Wed Jul 20, 2011 9:07 pm Post subject: |
Your engine may also run better with proper length plugs ;0) _________________ Current VWs 71 T2 Westy SO-72/6(Miami), 71 Crew Cab, 2015 GSW TDI
Other owned VW’s 59, 68 1500s, 69 & 71 Bug’s; 72 & 73 S-Bug’s; 67 Westy, 67 Deluxe, Other 71 DC, 72 KG GT that now lives in Australia, 12 JSW TDI, 2015 GSW TDI, 2023 Tiguan
VW technical information sights
thesamba - www.ratwell.com - www.shoptalkforums.com/ - www.vw-resource.com - http://www.type2.com/
http://bobhooversblog.blogspot.com/ - www.aircooled.net/gnrlsite/resource/articles.htm |
