vwbuser71 Samba Member
Joined: November 10, 2009 Posts: 13 Location: West palm Beach Fl
Posted: Sun Nov 27, 2011 8:00 am Post subject: What broke on my 71 Camper ? |
When backing my 71 camper out of the garage, it felt like the emergency brake was on , and it wouldn't roll. It finally let loose as the clutch was released, with a clunck. The bus drove Ok for about a mile, but then when starting out in 1st gear from a stop light, it bunny hopped a little and then a loud clunk from the rear, and she was dead. The engine was still running and I could shift, but no drivetrain. What did I brake? |
borninabus  Samba R&D Dept.
Joined: May 18, 2006 Posts: 4723 Location: Arizona Highways
Posted: Sun Nov 27, 2011 9:31 am Post subject: |
sounds like you you either stripped the splines in one of your drums or a CV fell off.
or your trans is kaput. but lets hope for the best  _________________ 88 Van WBX, A/T - 13 JSW TDI 6M/T - 2012 Touareg TDI Sport |
aeromech Samba Member
Joined: January 24, 2006 Posts: 17638 Location: San Diego, California
Posted: Sun Nov 27, 2011 10:17 am Post subject: |
Had the bus been parked for a while with the brake set? I'll bet your parking brake locked up. I suggest removing the rear drums for cleaning and inspection. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Westfabulous Samba Member
Joined: January 07, 2007 Posts: 4207 Location: The tropic of Canada, dodging the giant flying moose of Surrey!
Posted: Sun Nov 27, 2011 10:26 am Post subject: |
Could be CV's or it could be time for a new clutch. I'd look at these as part of my diagnosis. _________________ *****************
"I will gladly pay you Tuesday for a hamburger today." |
seventyfo Samba Member
Joined: February 13, 2007 Posts: 916 Location: Ocoee FL
Posted: Sun Nov 27, 2011 10:34 am Post subject: |
I second the strippedsplinesinthedrum theory. _________________ 85 Vanagon GL Westy GW 2.2 (Rebuilt by YT)
"I don't know you well enough to care about your comments". Watkins Cravey |
rustbus Samba Member
Posted: Sun Nov 27, 2011 10:49 am Post subject: |
threads like this should be a poll!
I vote CV came loose - have you looked underneath it yet? if it was CV it would be obvious.
drumroll! _________________ May of '72 Deluxe. 2.0L L-Jet CS & 091 trans conversion
my Bus thread |
SGKent  Samba Member
Joined: October 30, 2007 Posts: 42496 Location: at the beach
Posted: Sun Nov 27, 2011 12:16 pm Post subject: |
CV _________________ "Most people don't know what they're doing, and a lot of them are really good at it." - George Carlin |
71weekender Samba Member
Joined: August 07, 2005 Posts: 187 Location: olympia wa
Posted: Sun Nov 27, 2011 12:18 pm Post subject: |
cv |
Posted: Sun Nov 27, 2011 12:21 pm Post subject: |
Certainly easy to check for a stripped drum or busted CV. If those are all good then next would be something wrong with the pinon in the transaxle. |
SGKent  Samba Member
Posted: Sun Nov 27, 2011 12:24 pm Post subject: |
71 has a forged flange like a late bay. Pretty hard to strip them. _________________ "Most people don't know what they're doing, and a lot of them are really good at it." - George Carlin |
Posted: Sun Nov 27, 2011 12:49 pm Post subject: |
Thanks all, for the quick responses. Just checked the CV's and the drivers side
CV is broken off from the drum. Can I re-install it, or is replacement the best option. Any other damage I should be looking for to the drum Etc? |
SGKent  Samba Member
Posted: Sun Nov 27, 2011 1:06 pm Post subject: |
vwbuser71 wrote: |
post a photo _________________ "Most people don't know what they're doing, and a lot of them are really good at it." - George Carlin |
Posted: Sun Nov 27, 2011 5:50 pm Post subject: |
vwbuser71 wrote: |
If it is just the bolts have backed out or sheared, then new bolts may fix your problem. You will need to clean everything well to make sure the mating surfaces and the holes and threads for the bolts are not damaged. |
curtis4085 Samba Member
Posted: Sun Nov 27, 2011 6:00 pm Post subject: |
make sure to put a new boot on it when you replace the cv. Rochford has some great ones. Or you could get the CV join and german boot at busdepot and pop it on. I recommend Rockford and German CVS.
heres Rockford boot
_________________ Special Thanks to:
Headflow Masters - Vista, CA
www.headflowmasters.com |
Randy in Maine Samba Member
Posted: Sun Nov 27, 2011 6:24 pm Post subject: |
And at least repack the joint sine you are in there. If it were me, I would do all 4 of them since you are doing it anyway. I just hate for them to go bad in the middle of deep nowhere though.
Invest in new belleville washers (usually not included in the re-pack kits) and make sure you have all the torque spreaders. |
Posted: Sun Nov 27, 2011 6:33 pm Post subject: |
Randy in Maine wrote: |
now you lost me , newbie here torque spreaders is that the same thing as circlip spreaders and the belleville washer ? is the the dished washer? sorry newbie. _________________ Special Thanks to:
Posted: Sun Nov 27, 2011 6:38 pm Post subject: |
Each joint should have three plates under the bolt heads to spread the load onto the boot flange more evenly. The Belleville washers are the slightly curved washers that fit under the bolt heads but on top of the spreader plates.
The most important thing you can do (in my opinion) is to get the bolts tight enough. VW upped the recommended torque on the later Transporters (Vanagons) to 33 ft*lbs, IIRC. |
Desertbusman Samba Member
Posted: Sun Nov 27, 2011 7:46 pm Post subject: |
Time to remove both axles and go thru the 4 CV joints, maybe replace boots and probably get 24 new bolts and the special serrated washers. Then put it back together exactly per the book. If one failed the other 3 might also since it wasn't done right when they were put on before. _________________ 71 Superbug
71 Westy |
Posted: Sun Nov 27, 2011 8:39 pm Post subject: |
Wildthings wrote: |
awsome..i have those parts on order from VW just was not sure what he was talkiing about. Sorry for the thread high jack...
Definetly do all four CVS If you got one side thats failing the other not far behind. _________________ Special Thanks to:
SGKent  Samba Member
Posted: Sun Nov 27, 2011 9:18 pm Post subject: |
and check the tightness on the bolts every time you change the oil. If any feel lose retorque them all. _________________ "Most people don't know what they're doing, and a lot of them are really good at it." - George Carlin |
