1981 Ford F100 starting issues
jefflord
jefflord is offline
PostPosted: Tue Dec 06, 2011 1:25 pm    Post subject: 1981 Ford F100 starting issues Reply with quote
Okay I know this is a Vw forum but I have gotten so much help in the past with my bugs that I thought I would throw this one out there. On top of driving 40 year old cars my work truck is 30 years old. I started with what I thought was solenoid problem and it seems to continue. I have replaced the solenoid (twice) had the starter rebuilt, battery is good and alternator is charging. The truck will crank fine for several days then all of a sudden when I try and start it the battery drags like it is dead. If I play with it long enough it will finally turn over and start. One time though it never did start and that is when all the other parts were replaced and checked. Any advise would be greatly appreciated.
Thanks,
Jeff Very Happy
Fat Chicks need some loving too!
60ragtop
Bonneville Belt Bitch
60ragtop is offline
PostPosted: Tue Dec 06, 2011 1:44 pm    Post subject: Reply with quote
you need to put a meter on it when it is dragging and see what it reads.
Battery cables? Bad cell in battery, bad starter. Have you load tested the battery? Check voltage going to solenoid and coming out
Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote:
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote:
maybe he just snapped cause his car sucked Wink
jefflord
jefflord is offline
PostPosted: Tue Dec 06, 2011 3:02 pm    Post subject: Reply with quote
The only thing that has not been done is testing it when it is dragging. Never had a meter with me, but I do now Smile All the other test came up fine.
Thanks,
Jeff
Tram
Samba Socialist
Tram is offline
PostPosted: Tue Dec 06, 2011 3:17 pm    Post subject: Reply with quote
Flooding and hydro locking, or timing too advanced.
Bryan67 wrote:
Those who can- do.
Those who can't? Subaru.
bugger101
bugger101 is offline
PostPosted: Wed Dec 07, 2011 10:27 am    Post subject: Reply with quote
check your battery cables for high resistance using the ohms function on your meter. your battery should read 12.66 volts.
75 west deluxe http://www.thesamba.com/vw/forum/viewtopic.php?p=5270450#5270450
2010 ford focus
jefflord
jefflord is offline
PostPosted: Wed Dec 07, 2011 2:14 pm    Post subject: Reply with quote
12.56 Confused Starting to think it might be the timing issue. just strange that it doesn't do it all the time.
Very puzzled,
Jeff Smile
minger
minger is offline
PostPosted: Wed Dec 07, 2011 5:21 pm    Post subject: Reply with quote
Ignition swtich?
modok
modok is offline
PostPosted: Wed Dec 07, 2011 7:23 pm    Post subject: Reply with quote
I found a problem with some ford starters, the ones that use a relay under the hood and some kinda mechanical switch thing on the starter. ( i don't know what ford calls it)
The bendix and gear wore into the housing, so the gear was going out too far and jamming into the teeth of the flywheel and damaging the starter too.
I went to the autoparts store and got a rebuilt starter, it had the same problem, so i took it apart and put a big washer on the end to make up for the wear
It worked fine after that
johnnypan
johnnypan is offline
PostPosted: Wed Dec 07, 2011 8:02 pm    Post subject: Reply with quote
Check the ground strap between the engine and frame.
jefflord
jefflord is offline
PostPosted: Thu Dec 08, 2011 4:52 am    Post subject: Reply with quote
Okay, will check the ground strap today. Just wish it wasn't so flipping cold Laughing
Thanks,
Jee
jefflord
jefflord is offline
PostPosted: Sat Dec 17, 2011 7:30 pm    Post subject: Reply with quote
Latest on my F100. Many hours and several mechanics later. Turns out the fly wheel is warped. The fly wheel would be in a bind, starter would engauge but couldn't turn it past the spot it was binding in. This would cause the starter to pull too many amps and fuse the plates in the solenoid. This problem would happen randomly because it just depended where the warped spot in the fly wheel stopped when the truck was parked.
Thanks for all the input, no one on the ford forums ever responded Sad A lot more friendly people on this site !
Jeff Lord Very Happy
busdaddy
busdaddy is offline
PostPosted: Sat Dec 17, 2011 7:42 pm    Post subject: Reply with quote
BTDT with many other non VW forums, makes me appreciate the Samba and VW people more every day. Good to hear you got it beat even though it still sounds like work.
Слава Україні!
