My first Car,Bug and, Build
GreenbajaMachine
GreenbajaMachine is offline
PostPosted: Fri Dec 16, 2011 11:57 am    Post subject: My first Car,Bug and, Build Reply with quote
I got a 61 bug with a 1835 dual carb.
This is how i got it
Sold the sand tires got these Wrangler silent armour with kevlar
used her for a little while
This is partial inside
This is my dash and wiring
rear end
Front end
How it sat before i started
I removed the seats carpet most of the tar stuff, cut the cage welds off to remove it and this is what i got
Driver side
Passenger side
rear
shifter front
Cut out the cage
Coverting to irs i bought this tranny and stock boxed arm and jigs
started to remove motor
Got it off
Mounted my other tran fit perfect pic of them together
spring plate
crack in torsion
this was all done yesterday
Last edited by GreenbajaMachine on Fri Dec 16, 2011 12:43 pm; edited 2 times in total
Mal evolent
Mal evolent is offline
PostPosted: Fri Dec 16, 2011 12:14 pm    Post subject: Reply with quote
your 61 pan has a 65 or 66 body
73 Beetle Baja, Ghia front brakes, Type 3 rear brakes, 2220 ( 94 X 80 ), Weber Progressive, Bosch SVDA, '97 Mustang seats
Baja Bugs for Volkswagen Virgins: Index
The Phil
The Phil is offline
PostPosted: Fri Dec 16, 2011 12:28 pm    Post subject: Reply with quote
Looks just like my 66.
"In case I don't see you, good afternoon , good evening, and goodnight."
My '66 Baja Build Page http://www.thesamba.com/vw/forum/viewtopic.php?t=456365
Free from the evils of facebook Dec 2012. No other Social Media.
GreenbajaMachine
PostPosted: Fri Dec 16, 2011 12:44 pm    Post subject: Reply with quote
Thats nice to know how can you tell.
kbwakesk8
kbwakesk8 is offline
PostPosted: Fri Dec 16, 2011 1:19 pm    Post subject: Reply with quote
the size of the windows 61 has smaller windows
my first baja was a 61 pan on a 69 body.
The Phil
The Phil is offline
PostPosted: Fri Dec 16, 2011 1:30 pm    Post subject: Reply with quote
Wait a second, is your windshield curved? or flatish?
GreenbajaMachine
PostPosted: Fri Dec 16, 2011 1:42 pm    Post subject: Reply with quote
its mainly flat as lil curve dont they all. more flatish
My Baja Build
Mal evolent
PostPosted: Fri Dec 16, 2011 1:43 pm    Post subject: Reply with quote
I'm working on a series of ID tutorials. IDing bodies, pans and transaxles. It will be explained there.
short answer: window size '65 and later
no flap for the gas fill '67 and earlier
can't see the door handle, but it looks like the 66 and earlier style.
GreenbajaMachine
PostPosted: Fri Dec 16, 2011 1:44 pm    Post subject: Reply with quote
i have the pan number but i dont know where to find the bodys
My Baja Build
The Phil
The Phil is offline
PostPosted: Fri Dec 16, 2011 2:26 pm    Post subject: Reply with quote
Check for the body number upfront by the master cylinder. There should be plaque there. That's where mines at.
GreenbajaMachine
PostPosted: Sun Dec 18, 2011 5:55 pm    Post subject: Reply with quote
How would stock boxed trailing arms look with coilovers?
My Baja Build
thext94
thext94 is offline
PostPosted: Sun Dec 18, 2011 6:02 pm    Post subject: Reply with quote
What brand coilovers are you talking?
GreenbajaMachine
PostPosted: Sun Dec 18, 2011 10:37 pm    Post subject: Reply with quote
most likely fox not to sure yet still looking for good deal. any ideas what i should get.
My Baja Build
GreenbajaMachine
PostPosted: Mon Dec 19, 2011 9:55 pm    Post subject: Reply with quote
Got my swing axle transmission out. next come off the body.
My Baja Build
GreenbajaMachine
PostPosted: Mon Dec 19, 2011 10:05 pm    Post subject: Reply with quote
What would these be worth dual scat manifolds with solex carb
My Baja Build
The Phil
The Phil is offline
PostPosted: Mon Dec 19, 2011 10:51 pm    Post subject: Reply with quote
What condition are your carbs in?
GreenbajaMachine
PostPosted: Tue Dec 20, 2011 12:24 am    Post subject: Reply with quote
They are good i ran them before i tore the car apart ran fine. Cleaned them up to
My Baja Build
GreenbajaMachine
PostPosted: Mon Dec 26, 2011 11:44 pm    Post subject: Reply with quote
My Christmas Gift
My Baja Build
larryvance66
larryvance66 is offline
PostPosted: Tue Dec 27, 2011 4:15 am    Post subject: Reply with quote
$250 - $300 around here.
I got a Volkswagen for my wife....Best trade I ever made!
GreenbajaMachine
PostPosted: Tue Dec 27, 2011 2:11 pm    Post subject: Reply with quote
ok cool i try to get something around this area.
My Baja Build
