Interior quieting
RBEmerson
RBEmerson is offline
PostPosted: Thu Jan 05, 2012 12:42 pm    Post subject: Interior quieting Reply with quote
While pulling off the cabinet doors during a project to re-wire the 110 VAC outlet (added a GFCI), I noticed the remains of foam padding near the catch mechanism. I scraped the nasty remains off of the flanges and used some thin two-sided foam tape instead. Needless to say, I left the protective film on the foam on one side. I then did all of the remaining doors and the drawer. To my amazement, much of the noise I attributed to road and wind noise disappeared. While I would hardly call the Westy "Rolls-Royce quiet", it is surprisingly quieter. And all for a few minutes of scraping off old foam and putting fresh foam in its place.
Lord, give me coffee to change the things I can change, and wine to accept the things I can't change.
dubbified
dubbified is offline
PostPosted: Thu Jan 05, 2012 3:58 pm    Post subject: Reply with quote
I used several packs of Dynamat.
I have no doorcards, no flooring, and only a 7 seater, and front seats, a rubber floormat in the front.
Very quiet, can barely hear the engine.
I cant wait to finish the rest of the dynamat, insulate the top, and complete my interior work..
I want to pick up a cheap SPL meter.
RBEmerson
PostPosted: Thu Jan 05, 2012 4:12 pm    Post subject: Reply with quote
Your goal, to borrow from R-R, is "the only sound you hear is the ticking of the clock".
Were I to tear down the interior, I'd add some soundproofing, too. The interior is in no danger of being gutted. Smile
kamzcab86
kamzcab86 is offline
PostPosted: Thu Jan 05, 2012 4:18 pm    Post subject: Re: Interior quieting Reply with quote
Only remnants were on all the doors and drawer in my van. Replaced them all with something other than foam; only noise that went away was the only noise the cabinetry initially had: drawer squeak.
Some day I'll Dynamat (or similar) the interior, but until then road noise is no biggie to me. The one thing that makes a racket and drives me insane is that damn front table mounting bolt... I thought I had that solved, but driving the van the other day I discovered it's not! Brick wall Added padding to the top (which got squished with table use), so now I need to add padding to the bottom!
~Kamz Anxious
2016 Golf GTI S
PDXWesty
PDXWesty is offline
PostPosted: Thu Jan 05, 2012 4:32 pm    Post subject: Reply with quote
Stick a short piece of PVC pipe in there while driving and tighten the knob down. It will stop rattling. I think 1" is the right size.
89 Westy 2.1 Auto
nij_tp
nij_tp is offline
PostPosted: Thu Jan 05, 2012 4:36 pm    Post subject: lined two of my buses with FatMax Reply with quote
Its a cheaper option than Dynamat. Its possibly not as good but it has quited the interior of my buses.
1990 Vanagon GL _ Brunhilda (marked up as a Caravelle from new!) Just over 1/4 million miles, custom exhaust
1985 Vanagon GL - Josepha 140,000, Has a 2006 Forester 2.5 VVT custom exhaust
1989 Wolfsburg (Bluestar) - Walpurga
1989 Vanagon GL a parts bus
1984 Westralia
2006 Audi A4 2.0T with a unitronic tune
2007 Toyota Sequoia
1976 Mercury Capri 2.3l
1986 Honda Shadow VT700
2000 Suzuki Intruder VS800
1988 Kawasaki Voyager XII
2018 Chonda Hawk 250cc
1995 Subaru SVX (possible 3.3. swap)
randywebb
randywebb is offline
PostPosted: Thu Jan 05, 2012 4:51 pm    Post subject: Reply with quote
can you post a pic of the flange and the foam padding near the catch mechanism?
1986 2.1L Westy 2wd Auto Trans.
kamzcab86
PostPosted: Thu Jan 05, 2012 5:29 pm    Post subject: Reply with quote
Idea Now, why didn't I think of that?! I'll give that a try if/when the rubber stick-on gizmos fail.
What's left of the original foam on top; my replacement on bottom.
~Kamz Anxious
2016 Golf GTI S
skivan
skivan is offline
PostPosted: Thu Jan 05, 2012 5:33 pm    Post subject: Reply with quote
how about a curtain rattle fix (i have the plastic hooks). or is that just me? others find it an issue?
'87 subaru westy syncro
'04 TDI passat wagon
PDXWesty
PDXWesty is offline
PostPosted: Thu Jan 05, 2012 5:54 pm    Post subject: Reply with quote
I don't think the foam on the cabinet doors was stock. Neither of my vans had it. It must have been put on by a previous owner.
89 Westy 2.1 Auto
RCB
RCB is offline
PostPosted: Thu Jan 05, 2012 6:48 pm    Post subject: Reply with quote
I have the same remnants on the inside of all my doors/drawers as well. Not sure if the PO put it on or if its a factory thing. I removed all the leftovers and installed some moleskin. Now everything is quiet as a church mouse.
kamzcab86
PostPosted: Thu Jan 05, 2012 7:21 pm    Post subject: Reply with quote
These foam pads, or what's left of them, just look factory... extremely old, flaky foam that's precisely positioned on every single cabinet and drawer. In fact, it looks just like the old, smelly, flaky mattress foam on the upper bed (which I replaced).
I did some perusing through the brochures and found this in the '84:
Maybe some got them and some didn't? I've noticed that not all full-campers have that circuit breaker thing below the interior outlets too. Think
~Kamz Anxious
2016 Golf GTI S
tomkay
tomkay is offline
PostPosted: Thu Jan 05, 2012 7:27 pm    Post subject: Reply with quote
That drove me nuts trying to figure out what that was while I was driving down the highway.
Now, it drives me nuts knowing what it is. I always seem to forget about it once I stop.
Yes. Need to remedy that.
'87 Westy
DAIZEE
DAIZEE is offline
PostPosted: Fri Jan 06, 2012 7:53 am    Post subject: Reply with quote
question: can the Dynamat or like be used to prevent hot foot or do you have to use something specific for that area?. I'm now into making notes of materials needed.
'09 2.5L Jetta 5 cylinder, 5 spd, super turbo, see thread in H2O Cooled Jetta, etc...
84 Vanagon GL Wolfsburg Westy WBX 4 speed (sold)
oreana123
oreana123 is offline
PostPosted: Fri Jan 06, 2012 10:08 am    Post subject: Reply with quote
the roof patch material I purchased at home depot and covered my cab floor with has a layer of aluminum. The aluminum will help to block radiant heat from your floor. You might also consider additional insulation for conductive heat, at least your carpet mat.
dubbified
PostPosted: Fri Jan 06, 2012 4:51 pm    Post subject: Reply with quote
I personally wouldnt use dynamat where there's excessive heat, it is a butyl based product and will get gooey, if there is any traffic against it can get really tacky..
I applied dynamat very heavily to the front nose sections behind the dash, and to the floor sections in the front.
Prior to picking up the OE front rubber front mat, I let my feet touch the dynamat while driving.. it tracked nasty black goo across my carpet in the house..
Dynamat will definitely will deaden the sound... and as long as the surfaces are clean/wax/oil free, aint comin off. Recently I had to scrape some sections of dynamat off under the hood of my gti for paint.. what a job.. that stuff was really stuck on.. and it was only on for 8 mos.
randywebb
PostPosted: Fri Jan 06, 2012 5:11 pm    Post subject: Reply with quote
Use an engine liner material in areas that get hot - I usually use Cascade Audio's products as they are the only company I can find that has any knowledge whatsoever of acoustics or heat transfer.
http://www.cascadeaudio.com/car_noise_control/car_thermal_products.htm
DynaMat corp. would be my 2nd choice.
I would never put roof patch material inside my Vanagon -- if you do that, be sure to disclose to any one who buys your vehicle so you can immunize yourself from a liability suit.
DAIZEE
DAIZEE is offline
PostPosted: Fri Jan 06, 2012 5:19 pm    Post subject: Reply with quote
re those 'foam' patches, they look like they could be replaced with felt pads that come in different shapes, sizes with a sticky backing and could be easily cut to shape needed. In any hardware or convenience stores.
Thanks for info re sound proofing & hot foot. I don't have a sense of smell so I'll definitely look for something to go on front floor that does not melt or change shape or gets gooey!
Tram
Samba Socialist
Tram is offline
PostPosted: Fri Jan 06, 2012 5:31 pm    Post subject: Reply with quote
You don't want anything that can hold or absorb moisture against metal.
Bryan67 wrote:
Those who can- do.
Those who can't? Subaru.
westfailed
westfailed is offline
[quote="DAIZEE"]
Hot foot syndrome? Wouldn't it be better to fix the problem instead of mask it with foam? The heat comes from an open heat control right?
