ragtop man Samba Member
Posted: Sun Jan 08, 2012 6:57 pm Post subject: Does anyone fix the studs on a vw bus emblem? |
I have a nice bus front nose emblem all except for the mounting studs. two of them are broken off and the other two are not far from that. Is there anyone that can restore the mounting tabs on these bus emblems? thanks for any info on this.  |
KevinAlbrecht Samba Member
Joined: March 07, 2002 Posts: 993 Location: Ocean City > Boca > Pompano > Kirkland > Eugene > Sarasota
Posted: Sun Jan 08, 2012 7:27 pm Post subject: Re: does anyone fix the studs on a vw bus emblem?? |
ragtop man wrote: |
Would think it not too hard to weld on new studs, but for the cost, you could buy new?
http://www2.cip1.com/ProductDetails.asp?ProductCode=VWC%2D211%2D853%2D601%2DA _________________ Kevin Albrecht
1963 Panel
Don't forget those seat-belts!
Click to view image |
SCZ9-1-1 Samba Member
Joined: May 20, 2003 Posts: 716 Location: Santa Cruz, CA
Posted: Mon Jan 09, 2012 10:21 am Post subject: |
If you're not going for a 100% accurate resto I'd replace the studs with some threaded rod and use some wing nuts on the inside. I've heard using the clips is a PIA. |
type241 Samba Member
Joined: June 02, 2006 Posts: 1013 Location: MOSES LAKE, WA
Posted: Mon Jan 09, 2012 11:06 am Post subject: |
If you are dead set on "fixing" this emblem: TIG WELD and metal finish, but OG paint will be f'd in that area but it would be "fixed" |
Stocknazi Samba Member
Posted: Mon Jan 09, 2012 11:10 am Post subject: |
replacment posts would be a good aftermarket item, if you find an emblem that's still attached to the front of a bus around here, the posts are going to need work for sure.
of course you could use some small bolts, grind the heads round and weld them on. _________________ WANTED:
Thomas Jefferson |
Posted: Mon Jan 09, 2012 3:10 pm Post subject: |
thanks for all the help and suggestions on this. I may just let this emblem be wall art in my shop, If I dont try to fix it.  |
SkooobaSteve Samba Member
Joined: March 23, 2005 Posts: 3152 Location: Dothan Alabama
