Starting Problem
ckissick
ckissick is offline
PostPosted: Mon Jan 16, 2012 9:57 am    Post subject: Starting Problem Reply with quote
I tried the search, but ...
This is for my '83.5 Westy. About every fith try, the engine will start for a split second, then die. Then it will start right up. And the other day while going into a parking lot at night, the engine died and the headlights went out for a split second, then on again.
I'm thinking ignition swith. Any other ides? My grounds are good, and I have new vacuum hoses.
Charlie
1950 Beetle
1983 Westfalia
1989 syncro Tristar
1966 Porsche 912
1989 Beck Spyder
2007 GTI Fahrenheit
Tristar Eric
Tristar Eric is offline
PostPosted: Mon Jan 16, 2012 10:21 am    Post subject: Reply with quote
Since the headlights go through the ignition switch I think you answered your question.
It's easy enough to test your theory. Pop the column cover off, unplug the ignition switch, and plug a new switch in and activate with a flat blade screw driver.
