JKing'63 Samba Member
Joined: February 23, 2012 Posts: 56 Location: Anaheim, Ca
Posted: Thu Feb 23, 2012 8:48 pm Post subject: 1963 beetle coil |
| We've hooked up all the wiring, but what brings power to the coil? we're not getting any power at the distributor from the coil... need some help |
old DKP driver Samba Member
Joined: March 30, 2005 Posts: 4143 Location: Los Gatos,Ca.
Posted: Thu Feb 23, 2012 9:29 pm Post subject: coil power |
Hello Anaheim,
Thats where i grew up....
Look at the top of the page on the right side.
Go into Tecnical then to wiring. Scroll down to 1963 and open it.
There is a Black wire that comes from the TERMINAL 15/54 on the
"D" which represents the ignition switch.
It then feeds the #1 fuse on the fuse block.
when you turn the ign switch on it goes to the ignition coil.
Do you have Testing equipment? Test Light,volt meter?? _________________ V.W.owner since 1967 |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13589 Location: Tejas!
Posted: Thu Feb 23, 2012 10:06 pm Post subject: Re: 1963 beetle coil |
| JKing'63 wrote: |
power to the coil comes from the ignition switch. not fused, but on the fuse block, hooked to the same side as the wire coming from your ignition (should be a small black wire) _________________ Stop dead photo links! Post your photos to The Samba Gallery! |
Posted: Fri Feb 24, 2012 1:38 pm Post subject: |
| ok I'll check that out, thanks... we ended up just jumping from the B+ on the voltage regulator to the positive on the coil. Got it running which was our main goal, it was our first time having it running! exciting stuff... thanks a lot guys |
