trans question in regards to shortening a shift rod
kamikazeweasel
kamikazeweasel is offline
PostPosted: Sat Feb 25, 2012 9:34 pm    Post subject: trans question in regards to shortening a shift rod Reply with quote
I recently purchased a shortened rolling pan and need to shorten the shift rod but I want to make sure the trans is in neutral before I measure the length to cut it to. I don't have an engine yet to mount in it, so how do I tell if the trans is in neutral since the main transmission shaft is always spinning?
kustoms
kustoms is offline
PostPosted: Sat Feb 25, 2012 10:00 pm    Post subject: Reply with quote
The shaft / hocky stick will push in or pull out two times. Only push / pull one click. The shaft will be free to rotate a little
Google this.
"Bread and Circuses"
And wondering what the heck happen to my Samba post count?!?
Tom Thompson
Tijuana Kustoms Inc. (TM)
1-516-338-8746
www.tjkustoms.com
BL3Manx
BL3Manx is offline
PostPosted: Sun Feb 26, 2012 12:05 am    Post subject: Reply with quote
Put one of these in too.
http://www.thesamba.com/vw/classifieds/detail.php?id=722606
