How to wire the Carat Wolfsburg Edition subwoofer?
Waldemar Sikorski
Waldemar Sikorski is offline
PostPosted: Tue Mar 06, 2012 4:51 pm    Post subject: How to wire the Carat Wolfsburg Edition subwoofer? Reply with quote
Just installed a new aftermarket radio in to my 88/89 Carat Wolfsburg Edition almost syncro, but could not find anything as to how to, if doable, wire the left center panel sub-woofer. I think, that originally it plugs in to the factory radio with a 10 pin red connector. Anyone has done that?
Val.
crazyvwvanman
crazyvwvanman is offline
PostPosted: Tue Mar 06, 2012 5:52 pm    Post subject: Re: How to wire the Carat Wolfsburg Edition subwoofer? Reply with quote
There should also be an amp behind that panel to drive the subwoofer.
Mark
Val.
crazyvwvanman
PostPosted: Tue Mar 06, 2012 6:29 pm    Post subject: Re: How to wire the Carat Wolfsburg Edition subwoofer? Reply with quote
The amplified subwoofer wiring is shown on page 97.199 of the Vanagon Bentley.
Mark
Mark
Zeitgeist 13
Zeitgeist 13 is offline
PostPosted: Tue Mar 06, 2012 6:50 pm    Post subject: Reply with quote
Wait, there's an actual amp back there?
Casey--
'89 Bluestar ALH
'01 Weekender --> full camper
NEAT, no ICE.
crazyvwvanman
PostPosted: Tue Mar 06, 2012 7:14 pm    Post subject: Reply with quote
Sure is, on 89 that came with the 5th speaker in the center section, just check your original window sticker. Or remove the left side center panel.
Mark
Zeitgeist 13
PostPosted: Tue Mar 06, 2012 8:01 pm    Post subject: Reply with quote
Well I'll be...I've always snickered at the thought of calling that cheezy little speaker a "subwoofer". I guess it earns back a little cred
Casey--
'89 Bluestar ALH
NEAT, no ICE.
joetiger Premium Member
joetiger is offline
PostPosted: Wed Mar 07, 2012 8:39 am    Post subject: Reply with quote
Here's a thread on the original and an extremely well-done upgrade:
http://www.thesamba.com/vw/forum/viewtopic.php?t=364184&highlight=carat+subwoofer
Joe T.
'02 Baja-ish Beetle "Bubbles"
insyncro
Banned
insyncro is offline
PostPosted: Wed Mar 07, 2012 1:37 pm    Post subject: Reply with quote
Pictures of my spare subwoofer and wiring.
Yes the OG speaker is shot, but I use A/D/S woofers as a direct replacement and are much better in quality and sound.
I have three of these 89 interiors in vans.
My fav for sure.
elpedro
elpedro is offline
PostPosted: Thu Mar 08, 2012 11:48 pm    Post subject: Re: How to wire the Carat Wolfsburg Edition subwoofer? Reply with quote
Val.
I took the trouble to replace the sub driver in the 5th speaker enclosure in my Bluestar, and wired it to the new stereo harness. I have to say the 20 watts of bass was quite impressive with the engine off. But at highway speeds I couldn't even tell that it exists. So I wired up a cheap bazooka style sub and now I've got actual bass. In my opinion the stock sub is more trouble than it's worth because of the crappy amplifier but I'm sure someone's done a better job than I at it.
...Peter...
89 Vanagon Bluestar to-be-named
71 hardtop westfalia Brave Little Toaster *sold*
Waldemar Sikorski
PostPosted: Mon Mar 12, 2012 5:57 pm    Post subject: Reply with quote
Thanks everyone for the response. I might not do anything about it for now.
