cht guage accurate!
vwsb74
vwsb74 is offline
PostPosted: Sat Apr 28, 2012 9:48 pm    Post subject: cht guage accurate! Reply with quote
hi, which cht guage that reads close to accurate reading? I need the 12mm sender aswell. thanks
74 super beetle
2011 ford explorer traded
2010 mazda 3 hatchback
2014 Honda odyssey
2180cc 48IDA clone
Xr310 cam =171hp@6k rpm sold so as the car😢
tmcdade
tmcdade is offline
PostPosted: Sun Apr 29, 2012 6:05 am    Post subject: Re: cht guage accurate! Reply with quote
http://www.dakotadigital.com/index.cfm/page/ptype=...prd347.htm
Search the forums, but I think most are buying the 14mm sender and replacing the ring with a 12mm
Travis
1972 Super Beetle
1907cc
vwsb74
vwsb74 is offline
PostPosted: Sun Apr 29, 2012 9:13 am    Post subject: Re: cht guage accurate! Reply with quote
so where can I buy the 12mm ring then?thaks
74 super beetle
2014 Honda odyssey
2180cc 48IDA clone
Steve Arndt
Steve Arndt is offline
PostPosted: Sun Apr 29, 2012 11:15 am    Post subject: Reply with quote
You can crimp your own with a ring terminal that fits your plug. Cut off the 14mm that comes with the gauge, and crimp the wires to the 12mm ring.
tattooed_pariah
tattooed_pariah is offline
PostPosted: Sun Apr 29, 2012 11:41 am    Post subject: Reply with quote
wasn't there just a thread recently explaining that the ring terminal is actually a thermocouple and needs to be replaced with another one for it to work properly?
I might be wrong, I didn't read it too closely as I'm not at that point yet, but I thought it was saying something like that..
-pariah
'72 Volksrod
DarthWeber
DarthWeber is offline
PostPosted: Sun Apr 29, 2012 11:48 am    Post subject: Reply with quote
Here:
http://www.thesamba.com/vw/forum/viewtopic.php?t=509102
Mitey62 wrote:
Swapped the Compufire for a Bosch blue and some points I had sitting around, started 1st crank. Took her out for a drive, pulls harder, more RPM, and runs smoother. I think I'll be sticking with points from now on.
RockCrusher wrote:
JB weld the case halves....that'll keep the fretting to a minimum. Laughing
tattooed_pariah
PostPosted: Sun Apr 29, 2012 12:04 pm    Post subject: Reply with quote
DarthWeber wrote:
Here:
Thanks Glenn, knew I saw it somewhere and wasn't just remembering what the voices mumble... Wink
-pariah
'72 Volksrod
Steve Arndt
PostPosted: Mon Apr 30, 2012 8:16 am    Post subject: Reply with quote
We don't need to have another debate about TC theory. The ring is just a generic AMP crimp ring terminal.
W1K1
W1K1 is offline
PostPosted: Mon Apr 30, 2012 9:43 am    Post subject: Reply with quote
how much does it affect the readings if you lose 1/4" when grinding off the old ring terminal? Embarassed
1973 super 2110cc
1965 squareback 1500E-sold
1971 bay window westy- EJ2.5 subi swap
Steve Arndt
PostPosted: Mon Apr 30, 2012 3:51 pm    Post subject: Reply with quote
It won't change the reading if you duplicate the positioning and heat transfer into the crimp containing the hot junction of the two TC wires.
