Bus shifter + Sperrwolf lock?
mattlyons
mattlyons is offline
PostPosted: Mon Apr 30, 2012 10:19 am    Post subject: Bus shifter + Sperrwolf lock? Reply with quote
I want to install a bus shifter in a 57 beetle and I want to keep the Sperrwolf lock in place. From searching threads I've found that I'd need a shifter from a 60-65 bus. Will this still bolt right in with the Sperrwolf? What exactly else will I need to do, if anything? Any and all help is appreciated. Thanks in advance.
mandraks
mandraks is offline
PostPosted: Mon Apr 30, 2012 12:24 pm    Post subject: Reply with quote
matt,
i don't know the answer to your question, but i am curious as to why you want the bus shifter? i have always found the shifter in your picture perfectly adequate...
regards
Uli
L378
L378 is offline
PostPosted: Mon Apr 30, 2012 2:47 pm    Post subject: Reply with quote
The heck with why the bus shifter, I'd like to know about the leather steering wheel wrap - that's sweet! Who makes it?
RareAir
RareAir is offline
PostPosted: Mon Apr 30, 2012 4:27 pm    Post subject: Reply with quote
If you want to install a Type 2 shifter & keep the shifter lock, you need to install a "quick shift" spacer. This will compensate for the extra length beneath the shifters fulcrum point. You just need the spacer, not the spherical ball that also comes with the kit
1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241
RareAir
RareAir is offline
PostPosted: Mon Apr 30, 2012 4:28 pm    Post subject: Reply with quote
edit*
1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241
mattlyons
PostPosted: Mon Apr 30, 2012 9:13 pm    Post subject: Reply with quote
mandraks wrote:
matt,
It's not that it's not adequate...I just find myself reaching a little more than I'd like in an almost uncomfortable position. Nothing big really, I just think it would be more comfortable higher up and closer. I also think it looks really cool. Smile
(this is someone else's picture on here and I don't remember who's it is so sorry for that, not claiming it or anything)
mattlyons
PostPosted: Mon Apr 30, 2012 9:16 pm    Post subject: Reply with quote
And RareAir, Thanks a lot for the answer. I've seen your posts in every thread about this and I was actually going to pm you if I didn't get any results here. I figured you'd be the guy to ask. Thanks again.
mattlyons
PostPosted: Tue May 01, 2012 5:37 am    Post subject: Reply with quote
http://www.wheelskins.com/index.php
They're a little pricey.
L378
L378 is offline
PostPosted: Tue May 01, 2012 6:01 am    Post subject: Reply with quote
Thanks. Never seen a wheelskinz on a VW steering wheel before. Always thought they were too thick or something. In fact didn't think yours was a wheelskinz for that reason - yours looks nice! The bus shifter is fully 50's pickup - now you need a flat back bench seat Wink
mattlyons
PostPosted: Tue May 01, 2012 6:05 am    Post subject: Reply with quote
Look at that picture I posted though. Tell me that doesn't look bad ass. Cool
mattlyons
PostPosted: Tue May 01, 2012 6:07 am    Post subject: Reply with quote
Plus I don't want one of those obnoxiously tall shifters where you're reaching out the rag top to try and get 2nd gear.
Ghia Nut
Ghia Nut is offline
PostPosted: Tue May 01, 2012 8:02 am    Post subject: Reply with quote
mattlyons, I agree with you, it is a bit uncomfortable to reach all the way down there, I feel I almost have to bend down there.
'59 typ1 rajay turbo
'72 Ghia rajay 1641 dual 36DRLAs, 1 3/8" SS merged header and fat boy
78" GL Vert with ej22t swap
This will likely change tomorrow to something else.
View user's profile Send private message AIM Address Facebook Gallery Classifieds Feedback
L378
L378 is offline
PostPosted: Tue May 01, 2012 9:10 am    Post subject: Reply with quote
Never said it wasn't. To my eyes, very retro/old school. Ever think of putting a bus shift extender on?
mattlyons
PostPosted: Tue May 01, 2012 2:15 pm    Post subject: Reply with quote
Yeah I have but I'm not big on those. I like the idea of having 1 piece of metal and the extensions don't look right to me. The bus shifter almost looks like it could be stock.
L378
L378 is offline
PostPosted: Tue May 01, 2012 2:27 pm    Post subject: Reply with quote
In a 57 Chevy Stepside Exclamation Seriously, I get it, the bus shifter is pretty trick and certainly you don't see it everyday in a bug. Go to a show and people will certainly ask "what's up with that?" More effort than an extender, but like you said - looks better.
sub-hatchtim
sub-hatchtim is offline
PostPosted: Wed May 02, 2012 8:53 am    Post subject: Reply with quote
I had bus shifter's in my 65 and 67 bug and loved them
58' pg/sg silo fridge westy
58 Dove blue singlecab
76 911S
Ghia Nut
Ghia Nut is offline
PostPosted: Wed May 02, 2012 11:02 pm    Post subject: Reply with quote
Quick clarification... that picture with the bus shifter installed, its bent, which means it would need a notch for the bend to stay centered. Bay shifters are bent and have the notch, pre 67 shifters which are what are supposed to work are just straight. So what do you use to get that desired placement?
RareAir
RareAir is offline
PostPosted: Thu May 03, 2012 1:45 pm    Post subject: Reply with quote
1955-59 Bus shifters are straight. 1960-67 Bus shifters are bent like shown in the original photo above
1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241
berpsta
berpsta is offline
PostPosted: Thu May 03, 2012 2:59 pm    Post subject: Reply with quote
is a sperrwolf shifter a rare shifter/optional extra or standard fitment??
the bus shifter does look pretty cool tho
L378
L378 is offline
PostPosted: Thu May 03, 2012 4:09 pm    Post subject: Reply with quote
It was an accessory. An orginal sperrwolf shift lock is hard to find and can be rather pricey. It looks much the same as reproductions that can be found.
