eth727 Samba Member
Joined: February 21, 2007 Posts: 542 Location: san diego
Posted: Tue May 01, 2012 5:26 pm Post subject: How to install brake return springs? |
Is there some sort of special tool to install the return springs on '55 brake shoes? I bought brand new rear brake shoes and springs from wolfsburgwest and am having a hell of a time getting them on. I read the muir manual,bentley and watched the bug me videos and none of them mentioned any special tools to install the springs. |
Schwing Samba Member
Joined: May 10, 2009 Posts: 2508 Location: Centreville, MD
RareAir Samba Member
Joined: May 11, 2002 Posts: 14577 Location: 18 miles North of the border
eth727 Samba Member
Posted: Tue May 01, 2012 7:35 pm Post subject: |
how does that work? it looks something i used for an abortion once. |
79SuperVert Samba Member
Joined: May 31, 2002 Posts: 9758 Location: Elizabeth, NJ & La Isla Del Encanto
Posted: Tue May 01, 2012 8:27 pm Post subject: |
Unless oval brakes are completely different from big-window brakes, I hope this helps: I found a special tool was not needed. It was easier to hook up the springs to the shoes first off the car, then hook one end of the shoes into one cylinder, then the other end of the shoes onto the other cylinder, then put in the retaining pins and coil springs through the centers of the shoes. _________________ Central Jersey VW Society
Wanted: Art Collins VW (Savannah, Georgia) items - license plate surrounds and other items. Also ivory "AM", "FM" and "SW" buttons for a US Blaupunkt Frankfurt. |
Posted: Tue May 01, 2012 10:47 pm Post subject: |
eth727 wrote: |
You have a Ph.D in Gynecology? I'm going to have to charge you more for parts & services since you can afford it.
You attach one end of the spring onto the brake shoe. Then attach the hooked end of the tool to the other end of the spring. Insert your finger into the looped end of the tool. Now you can easily stretch the spring to the other brake shoe. Once you have the spring end attached to the shoe, you can slip the tool off the spring. _________________ 1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241 |
Russ Samba Member
Joined: January 12, 2003 Posts: 1560 Location: Langley B.C.
Posted: Wed May 02, 2012 12:08 pm Post subject: |
i have always used needle nose pliers and i have definitly let a few fly away but it gets the job done _________________ Cruiser pedals for sale (see my ad's)
55 hardtop finally finished
65 beetle done:) |
61SNRF Samba Member
Joined: March 29, 2009 Posts: 4656 Location: Whittier 90602
Posted: Wed May 02, 2012 1:26 pm Post subject: |
79SuperVert wrote: |
Unless oval brakes are completely different from big-window brakes, I hope this helps: I found a special tool was not needed. It was easier to hook up the springs to the shoes first off the car, then hook one end of the shoes into one cylinder, then the other end of the shoes onto the other cylinder, then put in the retaining pins and coil springs through the centers of the shoes. |
This is the same method I have used 100's of times.
It makes the rears super easy too. This way you can assemble the two shoes, the e-brake lever, stay bar and spring as a unit before placing it onto the backing plate.
With the pliers, they always leave a divot in the brake linings _________________ -Bruce
An ounce of prevention is worth a pound of cure. |
eth727 Samba Member
Posted: Wed May 02, 2012 5:30 pm Post subject: |
I don't know wtf but it seems the shoes that i bought from wolfsburgwest which are supposed to be 53-57 have the top holes different than the shoes that I removed-they don't even have holes on the top. i've allready ruined a couple of the springs from stretching them. let me get this straight the springs that are longer with the ends pointing together go on the top and the shorter ones with ends point away go on the bottom. |
61SNRF Samba Member
Posted: Wed May 02, 2012 5:54 pm Post subject: |
Maybe this pic of 57 rear brakes by Snort from the Gallery will help...
I can't tell you if you have the correct springs/shoes or not, I have not seen what they are selling for your car. I know I don't like WW's spring kits for '58-up. They are too generic and not like the originals at all. I'm sure if you call or e-mail them they will be happy to assist you.
But I can say that the stronger/larger of the springs always goes on the W/C side. _________________ -Bruce
Posted: Wed May 02, 2012 10:21 pm Post subject: |
61SNRF wrote: |
That photo is NOT representative of 1953-57 rear brakes. That photo is of a 1958-64 rear brake set up. _________________ 1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241 |
xeno Samba Member
Posted: Thu May 03, 2012 6:56 am Post subject: |
I've always used vice grips... _________________ Currenlty Corralled:
1952 Crotch Cooler Deluxe (US specs delivered to Stuttgart, Germany GI.)
1955 Early (Competition Motors - Hollywood, California)
1974 Thing (US specs - Mexicanos)
2008 Rabbit S (Wolfsburg DE)
2012 Golf TDI Tech Package (Wolfsburg DE) |
61SNRF Samba Member
Posted: Thu May 03, 2012 7:20 am Post subject: |
[quote="RareAir"]
61SNRF wrote: |
That photo is NOT representative of 1953-57 rear brakes. That photo is of a 1958-64 rear brake set up. |
Please excuse me for using the description entered by the submitter as fact
The shoes sure don't look like '58-'64 to me.
eth727, what do your brake parts look like?
Any of the above samples?
In either case, you still don't need any pliers if you hook up the springs to the shoes before you put them on the backing plate. _________________ -Bruce
Snort Samba Member
Joined: April 02, 2005 Posts: 1964 Location: Seattle, WA
Posted: Thu May 03, 2012 11:37 am Post subject: |
RareAir wrote: |
Thanks for catching that error. I've corrected the photo label in the gallery.  |
eth727 Samba Member
Posted: Thu May 03, 2012 1:24 pm Post subject: |
Hey does it matter if the stars are on the top or bottom? I forgot how mine went and installed them with the stars on top. |
Snort Samba Member
Posted: Thu May 03, 2012 1:28 pm Post subject: |
No, it doesn't matter. Ovals had the adjusters on the top, 58 and up on the bottom, essentially the same design but flipped. Either way seems to work fine. |
Blue Baron VW Aficionado
Joined: June 16, 2006 Posts: 28089 Location: Free State of Florida
Posted: Mon May 07, 2012 7:45 am Post subject: |
It makes a difference with how the parking brake cable attaches. _________________ We are striving for perfection, to make our cars run forever, if possible.
Heinz Nordhoff |
Snort Samba Member
Posted: Mon May 07, 2012 8:28 am Post subject: |
Parking brake cable can still be accommodated by switching backing plates from left to right depending on which style of cable your car has. |
