Use 2.0 Air Cooled Fuel Pressure Regulator on WBX?
Vanagon Nut
Vanagon Nut is offline
PostPosted: Wed May 16, 2012 5:54 pm    Post subject: Use 2.0 Air Cooled Fuel Pressure Regulator on WBX? Reply with quote
hi all. on my android. For some reason can't search.
The FPR can be pricey. At least locally. Anywhere from 156 to over $300. That said i may have a line on a good used FPR. However......
Is the AC FPR rated correctly for the WBX? If yes maybe reshape the bracket and run a "t" at the FPR inlet ?
Just a thought.
Neil.
1981 Westy DIY 15º ABA
(VW Gas I4)
1988 Westy DIY 50º ABA
VE7TBN
Ahwahnee
Ahwahnee is offline
PostPosted: Wed May 16, 2012 6:20 pm    Post subject: Reply with quote
Zounds! It was $71 on Amazon when I got one 3 weeks ago, now $106...
http://www.amazon.com/dp/B001CO2U4C/ref=pe_175190_21431760_A1_cs_sce_dp_1
Amazon prices sometimes seem to behave like airline seats, responding to spot demand.
Vanagon Nut
PostPosted: Wed May 16, 2012 6:48 pm    Post subject: Reply with quote
ya hypothetically speaking, if it was confirmed here or on some other popular forum, that the air cooled FPR could safely be used, i bet the price of that part would go up! Wink
(VW Gas I4)
VE7TBN
Vanagon Nut
PostPosted: Thu May 17, 2012 12:30 am    Post subject: Re: Use Air Cooled Fuel Pressure Regulator? Reply with quote
Vanagon Nut wrote:
Is the AC FPR rated correctly for the WBX? .....
Maybe it is.
Reading Bentley, the fuel pressure regulator specs shown for testing with vacuum line connected or disconnected are the same for air cooled and WBX; either 29 or 36 PSI respectively.
So aside from 2 added joins for a T from regulator inlet, and possible hose positioning hassles, why wouldn't one do this?
Or does the diaphragm/spring in the air cooled FPR operate in a totally different manner than the WBX part?
The air cooled part is less $ and possibly easier to find.
Neil.
(VW Gas I4)
VE7TBN
Vanagon Nut
PostPosted: Thu May 17, 2012 12:35 am    Post subject: Reply with quote
One source I'd forgotten to check. AZ Autohaus:
http://www.autohausaz.com/search/product.aspx?sid=...0Regulator
Now I'll never get one. Wink
Hopefully the locally available used part is what seller claims it is. (rust free, working)
Neil.
(VW Gas I4)
VE7TBN
Ahwahnee
Ahwahnee is offline
PostPosted: Thu May 17, 2012 6:30 am    Post subject: Reply with quote
Just to hopefully clarify, I think this is the part you're contemplating as a substitute:
Vanagon Nut
PostPosted: Thu May 17, 2012 8:23 am    Post subject: Reply with quote
Yes.
Neil.
(VW Gas I4)
VE7TBN
