thejoneses Samba Member
Posted: Sun May 27, 2012 7:14 am Post subject: My sliding door is stuck in the locked position! |
Hello
On a recent camping trip we returned to our van after a day out and found that both handles that operate the sliding door were both broken. When I push down on the handle there is no resistance and nothing happens. I have removed the door card to the sliding door but it looks like I have to get the door open in order to get into the lock. Does anyone know of some way to pop open the sliding door assuming it is still locked?
Many thanks! |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 53222 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sun May 27, 2012 7:24 am Post subject: |
Welcome!, it would help alot to know the year of your bus  _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
SGKent  Samba Member
Joined: October 30, 2007 Posts: 42958 Location: at the beach in Northern Wokistan
Posted: Mon May 28, 2012 12:47 am Post subject: |
we do know that the interior and exterior locks on the slider are independent of each other and that both have to be unlocked for the door to operate freely. Right? _________________
Canned Water - the new California approved parts cleaner (except in a drought in which case rub it with sand).
George Carlin:
Skills@EuroCarsPlus:
"never time to do it right but always time to do it twice"  |
NachoVW1971 Samba Member
Posted: Sat Mar 09, 2024 1:00 pm Post subject: Re: My sliding door is stuck in the locked position! |
| I am having a similar problem. I shut and locked from the inside. Now it is stuck locked. I can move the internal lock up and down and that is how I locked it. The outside lock has always worked and moved. But now it won't turn. I can't get the door open to figure out the lock problem. Any advice on how to get it open to look at it? It is a 1971 Bay Window. |
aeromech Samba Member
Joined: January 24, 2006 Posts: 17760 Location: San Diego, California
Posted: Sat Mar 09, 2024 1:09 pm Post subject: Re: My sliding door is stuck in the locked position! |
Are you sure the outside lock is unlocked? _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
mikedjames Samba Member
Joined: July 02, 2012 Posts: 3455 Location: Hamble, Hampshire, UK
Posted: Sat Mar 09, 2024 1:28 pm Post subject: Re: My sliding door is stuck in the locked position! |
I think you can gradually loosen the striker plate from the front pillar with a 13mm spanner in the gap.
Combine this with a pull on the cable under the door card to pop the back of the door open.
You will have to progressively undo the bolts on the front pillar as the door moves back.. _________________ Ancient vehicles and vessels
Posted: Sat Mar 09, 2024 1:41 pm Post subject: Re: My sliding door is stuck in the locked position! |
| Okay, I was able to remove the white plastic handle and push the square nut forward which pushed out the handle. I was able to open it. But the outside lock won't turn with the key. I think maybe the handle lock itself is broken. I tried putting lubricant into the lock to get it moving, but no luck. |
Posted: Sat Mar 09, 2024 2:07 pm Post subject: Re: My sliding door is stuck in the locked position! |
| Decided to replace entire handle and lock...to be continued. |
Posted: Sat Mar 09, 2024 3:07 pm Post subject: Re: My sliding door is stuck in the locked position! |
And you have a source for these parts ahead of time?, don't expect to find stuff like that in any on line catalog. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sat Mar 09, 2024 6:05 pm Post subject: Re: My sliding door is stuck in the locked position! |
When you turn the outside lock with the key, a dead bolt pops out. It engages a slot on the lock base and can be installed upside down. When this happens you can’t turn the key because the dead bolt can’t extend into the slot _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
