VW bus sunroof
lolpizowned
lolpizowned is offline
PostPosted: Fri Dec 28, 2012 8:20 pm    Post subject: VW bus sunroof Reply with quote
Does a 1977 sunroof fit a 1971?
aeromech
aeromech is offline
PostPosted: Fri Dec 28, 2012 10:52 pm    Post subject: Reply with quote
I think so
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Collie
Collie is offline
PostPosted: Sat Dec 29, 2012 10:46 am    Post subject: Re: VW bus sunroof Reply with quote
Is the '71 a sunroof bus now?
Or a camper with just the sunroof hole?
Or is it a hardtop you want to put a sunroof in?
lolpizowned
PostPosted: Sat Dec 29, 2012 12:25 pm    Post subject: Reply with quote
the 71 is a deluxe with the sunroof hole and hardware but im missing the actual panel and the panel is coming from a 77
Collie
Collie is offline
PostPosted: Sat Dec 29, 2012 12:27 pm    Post subject: Reply with quote
Then, yes, you are good to go!
lolpizowned
PostPosted: Sat Dec 29, 2012 12:31 pm    Post subject: Reply with quote
great to hear thank you!
SGKent Premium Member
SGKent is offline
PostPosted: Sat Dec 29, 2012 1:08 pm    Post subject: Reply with quote
before you go to a lot of work, check the area on the bus at the back outside of the opening and forward from that spot 12" to see if rust has formed.
Check your bus to see if you will need to repair the area and check the donor as I am looking for sheet metal in this area to replace mine as it has pin holes. EVERY bus I have inspected, even those in a dry climate have rust pin holes there as it rusts from the inside in that area.
George Carlin:
Skills@EuroCarsPlus:
1971 deluxe (sold)
1977 deluxe
aeromech
aeromech is offline
PostPosted: Sat Dec 29, 2012 2:21 pm    Post subject: Reply with quote
Also, before you even begin to do this job I suggest you evaluate what parts you'll need and begin sourcing them. The prices can be sky high and many parts just aren't available from parts houses. Finding good used parts can be an adventure. Be prepared to spend $500 +
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
aeromech
aeromech is offline
PostPosted: Sat Dec 29, 2012 4:36 pm    Post subject: Reply with quote
Here's a cheap solution I just found
http://sandiego.craigslist.org/esd/pts/3508896635.html
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
