plane_ben Samba Member
Joined: February 27, 2005 Posts: 349 Location: Tucson, AZ
Posted: Thu Apr 04, 2013 7:18 pm Post subject: Voltage drop to points on a 12 volt system |
Visiting with a friend this evening that is a vertual encyclopedia on anything automotive when the discussion turned to ignition points.
He was saying that a 12 volt system running points should only have 6 volts at the distributor. American cars used a resistive wire from the coil to the distributor to drop the voltage. I've never heard of this before. Does VW do this as well through either a resistive wire or something internal in the distributor?
One of the reasons I ask is I just burnt up a set of points after about four months dayly driving my bus. They were adjusted at .016 per VW specs, timing is spot on. But the other day I noticed an ocssional miss, then it just quit. Luckily I had a spare used set of points and got home alright. Been spoiled with the electronic points replacement the last few VWs I've owned.  _________________ I'm at the age were "fuck off", "fuck you", and "fuck it" answer most questions. |
slow36hp scott wimberley
Joined: August 09, 2004 Posts: 3113 Location: mukilteo washington
Mile High Puma Samba Member
Joined: November 11, 2009 Posts: 241 Location: Salida, Colorado
Posted: Thu Apr 04, 2013 7:42 pm Post subject: |
I remember working on older cars with points that had a ballast resistor. On Chryslers it was mounted on the firewall and on Chevy's I believe it was built into the coil to drop the voltage to about 9 volts after the car was started. The VW ones might be in the coil. _________________ 1965 Velvet Green DC
1990 Westfalia Syncro |
Posted: Thu Apr 04, 2013 10:26 pm Post subject: |
I remember my old '64 Corvar had a ballest resistor too. It shorted out one night and burnt the points up just as I was pulling up in front of my house. Wouldn't start the next day. Took me a few days to figure it out and only then after several calls to my dad explaining the symtoms.
I'm going to put a meter on the positive side of my bus coil in the morning and see whats what. _________________ I'm at the age were "fuck off", "fuck you", and "fuck it" answer most questions. |
j.pickens Samba Member
Joined: December 03, 2002 Posts: 9831 Location: Exit 7, New Jersey
Posted: Thu Apr 04, 2013 10:51 pm Post subject: |
Its 12 volts, or more likely a bit more, whatever your battery/generator/voltage regulator is putting out. It's a direct connection from the positive circuit to the coil. _________________ Founder and Chairman Emeritus, ECMSAS
BeaterBarndoor wrote: |
i wish more people would actually drive their vws rather than just talking about what they have in the garage. |
Red Fau Veh wrote: |
If you've seen one sunroof swivel seat kombi, you've seen them all!  |
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20812 Location: Sandpoint, ID
Posted: Thu Apr 04, 2013 10:55 pm Post subject: |
Aren't proper coils for A/C VW's internally resisted? I always thought they were, for the exact reason stated by the OP. _________________ You can't spell sausage without "USA"! |
Posted: Thu Apr 04, 2013 11:22 pm Post subject: |
cdennisg wrote: |
Aren't proper coils for A/C VW's internally resisted? I always thought they were, for the exact reason stated by the OP. |
Yes, but if you're talking about measuring the voltage at the condenser side of the coil, or at the points, that will be constantly changing. It's grounded when the points close, and varying as the charge on the primary builds up before the next spark discharges. Plus the residual from the condenser which is designed to prolong the spark discharge time.
Here's a typical primary circuit voltage waveform. Note the 300 volt peak. That's not the secondary coil spark, that's the primary which causes the secondary to discharge.
[img]www.picoauto.com/automotivetopics/waveforms/primary.gif[/img] _________________ Founder and Chairman Emeritus, ECMSAS
telford dorr Samba Member
Joined: March 11, 2009 Posts: 3625 Location: San Diego (Encinitas)
Posted: Fri Apr 05, 2013 10:52 am Post subject: |
There should be 12 volts at the coil (terminal 15). Any needed resistance is inside the coil itself. There is no difference in points used on 12 volt systems from those used on 6 volt. You could conceivably use a 6 volt coil on a 12 volt system by adding external resistance (same value as the coil primary), but I'd recommend using a 12 volt volt instead. _________________ '71 panel, now with FI
More VW electrical at http://telforddorr.com/ (available 9am to 9pm PST) |
Posted: Fri Apr 05, 2013 6:51 pm Post subject: |
Measured 8.5 volts out of the negative side of the coil today. I have the Bocsh blue coil. So I guess that answere my question. _________________ I'm at the age were "fuck off", "fuck you", and "fuck it" answer most questions. |
Posted: Sat Apr 06, 2013 8:56 am Post subject: |
If you are burning up points you might want to put in a new condenser, they are there to reduce the arcing of the point contacts as they open and close. I even had a brand new one I put in a Subaru once that was bad and the car ran awful. _________________ 1965 Velvet Green DC
64 ragtop volks Samba Member
Posted: Sat Apr 06, 2013 9:23 am Post subject: |
If your only gapping the points that might be part of your problem.i dont care what the point gap is, its the dwell that really matters.what ever it takes to get 50 deg + or- 2 degrees using a dwell meter.would you set your timing with the motor not running, static time it or do you use a timing light to set it with the motor running.using the dwell meter is the same principle, its a pain in the ass removing the damn cap several times to get it right.vw should have copied chevy's dist cap it had a little window you slid up and used a small allen wrench to adjust the points with it running..or scrap the points\condinser and go petronix |
Posted: Sat Apr 06, 2013 4:07 pm Post subject: |
I always hook up the dwell and timing ligt after messing with pionts. I set my points at .016 to start and adjust from there. I can never remember witch way to go when adjusting the dwell number depending on point gap and usually go the wrong way before getting it right.  _________________ I'm at the age were "fuck off", "fuck you", and "fuck it" answer most questions. |
Posted: Sat Apr 06, 2013 5:20 pm Post subject: |
plane_ben wrote: |
I always hook up the dwell and timing ligt after messing with pionts. I set my points at .016 to start and adjust from there. I can never remember witch way to go when adjusting the dwell number depending on point gap and usually go the wrong way before getting it right.  |
I think it was Jon Muir who taught me that "if the dwell is too high, the points are too far open". That is how I remember it from oh so long ago. _________________ You can't spell sausage without "USA"! |
