BusBerd Samba Member
Joined: November 19, 2005 Posts: 837 Location: Minneapolis, MN
Posted: Wed Jun 05, 2013 4:39 pm Post subject: re-installing engine |
I am trying to install my engine. It will not slide on to the tranny's input shaft.
I had not taken off my clutch before, but I did this time to replace the rear main seal. So, when I put the clutch back together I noticed that the holes for the tranny's input shaft do not automatically just line up together. I have been trying to just "eye" it when I put the clutch back together but with no luck and it is getting REALLY frustrating. How can I make sure it is perfectly lined up for the shaft from the tranny to slide right in?
Also, what kind of grease should I use on the input shaft??
thanks! hoping to get this installed tonight... _________________ "The large print giveth and the small print taketh away."
1977 Westfalia Camper Bus 2.0L Fuel Injected Engine, Manual Transmission |
retroman Samba Member
Joined: November 02, 2010 Posts: 237 Location: Reno (What is Rust???)
Posted: Wed Jun 05, 2013 4:44 pm Post subject: |
You need a pilot tool. It looks like your trans output shaft and you put it in the clutch disc and the pilot bearing. Then tighten clutch assy and remove. I've seen them on samba. _________________ 1967 bug recovering from a PO
1987 Vanagon Wolfsburg Weekender "Otto" been all over the place with never a problem! |
crushie Samba Member
Joined: September 23, 2011 Posts: 878 Location: alberta
Posted: Wed Jun 05, 2013 4:52 pm Post subject: |
Also, turn the engine crankshaft bolt using a socket and ratchet while inserting the transmission, this usually lines everything together.
I also used to use longer bolts to get everything lined up, then replaced with the proper length bolts as the transmission, engine and bell housing meshed up.  _________________ 1974 VW Combi 1800 Auto. Weber 32/36 |
Posted: Wed Jun 05, 2013 5:04 pm Post subject: |
Damn. sounds like I ain't going to get a pilot tool tonight. _________________ "The large print giveth and the small print taketh away."
Posted: Wed Jun 05, 2013 5:09 pm Post subject: |
BusBerd wrote: |
Damn. sounds like I ain't going to get a pilot tool tonight. |
I installed several transmissions without a pilot tool.  _________________ 1974 VW Combi 1800 Auto. Weber 32/36 |
Posted: Wed Jun 05, 2013 5:12 pm Post subject: |
crushie wrote: |
BusBerd wrote: |
I installed several transmissions without a pilot tool.  |
how? _________________ "The large print giveth and the small print taketh away."
busdaddy Samba Member
Joined: February 12, 2004 Posts: 52750 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Wed Jun 05, 2013 5:13 pm Post subject: |
The approriate amount of carefully wound tape on a socket extension or dowel will do in a pinch, make sure it fits the pilot hole and clutch well. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
grtfldan Samba Member
Joined: December 06, 2007 Posts: 141 Location: Maryland
Posted: Wed Jun 05, 2013 5:50 pm Post subject: |
A small mag lite fits as well. _________________ 79 Bay 2.0 Fuel Injection
79 Bay project |
shaunone Samba Member
Posted: Wed Jun 05, 2013 5:53 pm Post subject: |
It can even be tricky with an alignment tool. You have to visually center the pilot tool before you tighten the pressure plate bolts. The input shaft gets moly powder, not grease. _________________
Tom Powell wrote: |
Olddog52 wrote: |
one tab to ground, the other to a 12 volt source. Listen intently for a sound. |
I put the horn next to my ear and I could hear the ocean.
When I hooked up the battery I couldn't hear anything for three days.
1977 Westfalia with a 1974 1800 Type 4 engine |
Derek Cobb Annoying
Posted: Wed Jun 05, 2013 5:57 pm Post subject: |
I've used a broomstick, extension wrapped in tape, basically anything that is straight, and fits snuggly in the hole. |
Posted: Wed Jun 05, 2013 6:33 pm Post subject: |
I have been trying a couple different things but no go. It looks centered to me. When I think I have it centered, I tighten it down and I check it with a much smaller bolt, sliding it along the perimeter inside to see if it catches evenly on the case (hard to explain). Anyway, just double checking it is centered.
I have messaged on our city's facebook group to see if anyone has the pilot tool and a few do so I am going to see if i can get out yet tonight to borrow it. We have a bus get together for Colin tomorrow night that i would like to drive the bus to. tonight is my only chance to work on it til then. _________________ "The large print giveth and the small print taketh away."
VDubTech Samba Member
Joined: December 29, 2002 Posts: 9155 Location: Syracuse, NY
Posted: Wed Jun 05, 2013 7:36 pm Post subject: |
One more of the many reasons to remove and install the engine and transmission as a unit. I never have trouble mating the engine and transmission, because it's done on the ground. I center the clutch disc with the transmission. _________________ First Trip in the RustyBus:
http://www.thesamba.com/vw/forum/viewtopic.php?t=279077&highlight=
borninabus wrote: |
a measurement of your rod would be extremely useful. |
notchboy wrote: |
my dad wasnt a belittling cock when he tought me how to wrench on cars. |
EverettB wrote: |
One photo = good for reference.
10 photos = douchebaggery |
mtcamper Samba Member
Posted: Wed Jun 05, 2013 7:41 pm Post subject: |
VDubTech wrote: |
One more of the many reasons to remove and install the engine and transmission as a unit. I never have trouble mating the engine and transmission, because it's done on the ground. I center the clutch disc with the transmission. |
I could not agree more. You could still drop the tranny, it's only like 2 more bolts, clutch cable and cv's and be done with it. Just saying it is way easier reinstalling engine and tranny as one. |
Keith Samba Member
Joined: August 15, 2005 Posts: 3632 Location: Brodheadsville, PA
Posted: Wed Jun 05, 2013 7:53 pm Post subject: |
mtcamper wrote: |
VDubTech wrote: |
X3 ! Having struggled a few times removing and installing a type IV engine the type I way ( just the engine) I finally got frustrated and pulled the engine and trans as a unit and holy shit was that easier !!!! Never again will they come out or go in separate. _________________ Formerly known in the forums as "OVALTEEN"
"I firmly believe that some villagers from Botswana could probably build a better road than PennDot."- Splitty
"If you do anything to your car someone will hate on you for it. People absolutely love to complain and find fault with others. Don't let it bother you. Just live and have fun."- Lind |
Joey Samba Member
Joined: August 12, 2005 Posts: 5375 Location: Nova Scotia - Canada
Posted: Wed Jun 05, 2013 8:39 pm Post subject: |
mtcamper wrote: |
VDubTech wrote: |
If his clutch disc is not centered in the flywheel is doesn't matter if the transmission is in the bus or on the ground it still isn't going to go together.
To make removing and reinstalling a type 4 engine easier I remove the bottom two engine to transmission studs. I use the double nut method to get them out. Just remember to place the studs in the holes in the transmission before installing the engine. _________________ Joey
‘60 Kombi - '74 Bus - '79 Panel - '65 Beetle |
Posted: Wed Jun 05, 2013 8:45 pm Post subject: |
Joey wrote: |
mtcamper wrote: |
VDubTech wrote: |
If his clutch disc is not centered in the flywheel is doesn't matter if the transmission is in the bus or on the ground it still isn't going to go together. |
True, but it's a shitload easier to center the clutch with the engine and transmission on the ground than dangling off of your floor jack. Loosen the pressure plate, line the transmission up and mate it with the engine to center the disc, pull the tranny back off and torque the bolts. Bolt the transmission to the engine and put it all back in at once. So.Much.Easier. _________________ First Trip in the RustyBus:
borninabus wrote: |
notchboy wrote: |
EverettB wrote: |
larrydeville Samba Member
Joined: October 21, 2011 Posts: 184 Location: Yuba City Ca
Posted: Wed Jun 05, 2013 8:45 pm Post subject: alighment of clutch/engine install. |
When we purchased our 77 camper the engine was out in pieces parts and wrong...a 1.7L After putting the right thing together I figured out if someone got it out with the tranny in I could get it back in....if no then I would drop the tranny. Now I see why some of the tin was MISSING. To go in I removed the most aft tin and put two layers of cardboard between the cooling shroud and the inside edge of the engine compartment as I weasled the motor in. I had it on a floor jack that rolled nicely. Then I installed the exhaust system. Next time I will try it the correct way but I hate the ball bearings in the CV joints that try to fall out. ....good luck...Larry |
Posted: Wed Jun 05, 2013 9:09 pm Post subject: |
You have the engine out so maybe you should just pull the trans out and assemble the two on the ground. The trans and engine must be perpendicular to one another in order for the two to mesh. A pilot tool is not necessary but as suggested improvise, use a socket extension and a shouldered deep socket. Line up the friction disc, and torque the pressure plate. Visually check the alignment, then make sure the engine and trans are perpendicular to one another, using longer bolts to then bring the two together. Also turning the engine over using a ratchet and socket on the crankshaft bolt while tightening the bolts will help to mesh the two.
MORE TIPS BELOW.
http://grassrootsmotorsports.com/forum/grm/speakin...455/page1/ _________________ 1974 VW Combi 1800 Auto. Weber 32/36 |
SGKent  Samba Member
Joined: October 30, 2007 Posts: 42444 Location: at the beach
Posted: Wed Jun 05, 2013 9:23 pm Post subject: |
You need 4 things.
1. The clutch driven disk must slide on the trans input shaft freely. If it is the wrong size or there are burrs, they can stop you. Slide the disk on first by itself to be sure it slides easily.
2. The disk must be centered. Normally you use a cheap $3 tool. Any flaps should have one for a VW bug or bus
3. The engine and the transmission must be parallel. You look at the width between the two and make sure it stays even as they are put together.
4. You must rotate the engine crank or put it in gear with a block under one wheel and spin the other. This spins the input shaft because the splines must align.
You use a little dab of moly grease on the input shaft if you don't have moly powder. You use a little moly grease inside the pilot bearing and a little on the nose of the input shaft. If you use too much it will get on the clutch and possible drive the pilot bearing out. You can fight it four or five times and the sixth it will slide together almost on its own. _________________ "Most people don't know what they're doing, and a lot of them are really good at it." - George Carlin |
archemitis Samba Member
Joined: November 07, 2012 Posts: 229 Location: minneapolis mn
Posted: Thu Jun 06, 2013 6:38 am Post subject: |
when its aligned properly it will just fall together and surprise the crap out of you, tranny in or out, long studs or none. |
