downshifting into 2nd gear grinds
m.abbadessa
m.abbadessa is offline
PostPosted: Sat Jul 13, 2013 9:40 am    Post subject: downshifting into 2nd gear grinds Reply with quote
When i down shift from third gear into second gear I have to slow down super slow to eliminate the grinding noise. It will still slip into gear it just grinds briefly. Any ideas on the best way to adjust or fix this?
EVfun Premium Member
EVfun is offline
PostPosted: Sat Jul 13, 2013 10:18 am    Post subject: Reply with quote
I recommend you replace your gear oil with a synthetic GL-4 gear oil. Avoid GL-5 gear oil since they can make grinding worse. My choice is Redline MT-90 gear oil.
Wildthings wrote:
167luckycharm
167luckycharm is offline
PostPosted: Sat Jul 13, 2013 10:22 am    Post subject: Reply with quote
Have you checked the gear oil level in the transaxle? With the side plug removed (17mm Allen style), the fluid should be near the bottom of the opening. When I learned how to drive my VW, I was taught to raise the engine rpm slightly before downshifting into 3rd and 2nd from the higher gear, but never into first while moving. Does it still grind if you rev it a little just before you shift it into 2nd?
Humble Pie, it might be good for you, but it always tastes like sh!t
See my 009 Distributor page on Facebook, search for VW 009 Distributor Discussion
http://www.facebook.com/pages/VW-009-Distributor-Discussion/499742640126712
joescoolcustoms
joescoolcustoms is offline
PostPosted: Sat Jul 13, 2013 11:04 am    Post subject: Reply with quote
The change in gear can help if the syncro is not all the way worn out.
If the oil change does not help the grinding, the only fix is to replace the syncronizer inside the tranny. The longer it is waited to fix the syncro problem, the worse the shift hub for 2nd gear will wear and may also need replacing.
Bad News Racing 2018 NORRA 1000 3rd in Class
Looks like it was painted with a live chicken,polished with a brick and buffed with a pine cone
m.abbadessa
PostPosted: Sat Jul 13, 2013 12:18 pm    Post subject: Reply with quote
Thanks for all the help. I have fresh topped off gear oil in it. I still have yet to try synthetic or revving the engine a little before downshifting. I will try both. Thanks
clonebug
clonebug is offline
PostPosted: Sat Jul 13, 2013 12:42 pm    Post subject: Reply with quote
I had the same problem.....it was the syncros.
It cost me $350.00 to have the trans gone through replacing reverse gear, welding third and fourth, new main bearing and replacing the worn out sycros.
Everything else was in great shape.
richardcraineum wrote:
I'm so ignorant of efi I don't even know the difference between batch, sequential blah blah blah ..
cbeck wrote:
His user name in a previous life was dick head.
Water/Alcohol Injection
Audi TT intercooler
Upgraded to MS3Pro-Evo
EcuMaster PMU16
ECUMaster ADU5 Digital Dash
http://www.shoptalkforums.com/viewtopic.php?f=3&t=127936
