91 Vanagon hot starting problems
tcarr1212
tcarr1212 is offline
PostPosted: Mon Nov 18, 2013 7:53 pm    Post subject: 91 Vanagon hot starting problems Reply with quote
Van doesn't want to start after getting up to normal temp. Will start cold every time. Replaced fuel pressure regulator and coil. No change. Will start if I let starter go a while, engine speeds up and finally sputters to start and then lets out a squeal like a tight engine belt. Any thoughts?
Thanks, Red Vanagon Brick wall
randywebb
randywebb is offline
PostPosted: Mon Nov 18, 2013 8:07 pm    Post subject: Reply with quote
1. clean the grounds
2. replace the temp II sensor
3. install the hot crank relay from Jay & clean all the existing connections carefully when you do it
1986 2.1L Westy 2wd Auto Trans.
alnvilma
alnvilma is offline
PostPosted: Mon Nov 18, 2013 8:17 pm    Post subject: Reply with quote
I've sure been there!
Replaced my starter and still had the same issue. Replaced that rebuilt under warranty with yet another and added another ground cable to the frame from the mounting bolt. Don't know which one of those actually fixed the problem!
Van-Cafe sells a new starter to alternator cable (2 different sixe ends crimped on a 12 gauge ) that bolts on top of the existing one. Supposed to help.
Personally, I think your starter armature is dragging when things get toasty. Or, maybe just the pilot bearing is worn....nah.
Good luck.
randywebb
PostPosted: Mon Nov 18, 2013 8:32 pm    Post subject: Reply with quote
yes, that would be #4 on my list, which is in increase order of parts cost
Jake de Villiers
Jake de Villiers is offline
PostPosted: Tue Nov 19, 2013 11:43 am    Post subject: Re: 91 Vanagon hot starting problems Reply with quote
The squeal is from a LOOSE drive belt, not a tight one. It might explain your lack of starting if its the alternator belt! Wink
'84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com
tcarr1212
PostPosted: Wed Nov 20, 2013 1:17 pm    Post subject: Reply with quote
Wouldn't a loose belt squeal every time I start it as opposed to only when it finally starts when it is hot?
Jake de Villiers
PostPosted: Wed Nov 20, 2013 2:08 pm    Post subject: Reply with quote
It squeals when there is enough resistance ie you've run the battery down spinning the starter with no result.
www.thebassspa.com
tcarr1212
PostPosted: Fri Nov 29, 2013 9:50 pm    Post subject: Reply with quote
Thanks everyone. Replaced the temp II sensor, tightened the alt belt and she is doing great.
