dpetteng Samba Member
Posted: Tue Jan 21, 2014 8:19 am Post subject: Glass |
| I am thinking of having custom glass made for my doors and rear quarterlights as I cant find any without scratches but not sure how thick standard glass is as I am not at home, anyone know how thick it is? |
GjMan Samba Member
Joined: June 05, 2004 Posts: 834 Location: Grand Junction, CO
Posted: Tue Jan 21, 2014 9:02 am Post subject: |
| A quick measurement of a piece of door glass in my garage shows a thickness of 0.186 inch. |
vwfye Samba Member
Posted: Tue Jan 21, 2014 9:17 am Post subject: |
GLass polishing kits and elbow grease might save you some serious $ _________________ 64 No'back Speedster "Pearl"
LME "Little Giant Killer 3"
1974 Ghia "PUK" |
Posted: Tue Jan 21, 2014 9:19 am Post subject: |
already tried the polishing, too deep...
Thanks GJman, that means 3/16th, just what I guessed |
jaransonT3  Samba Member
Joined: January 01, 2005 Posts: 1336 Location: Dearborn, MI
Posted: Tue Jan 21, 2014 11:21 am Post subject: |
Make sure you have them temper the glass after it is cut to size and shape. You don't want plate glass in there. You could use laminated safety glass, but it is not recommended for side and rear glass. _________________ Later,
John Jaranson
'66 Square (Sophy)
'67 Type 34 Karmann Ghia
'70-1 Fasty (Jane - the Lead Sled project)
'71 Westy (Sialia)
https://www.carartbyjohn.com
https://www.carartbyjohn.com/2026Invasion/ |
vlad01 Samba Member
Joined: October 27, 2010 Posts: 3064 Location: Australia
Posted: Tue Jan 21, 2014 3:36 pm Post subject: |
| vwfye wrote: |
| GLass polishing kits and elbow grease might save you some serious $ |
tempered glass is too hard to polish by hand. Sometime a window/glass shop can do it.
I tried on tempered glass on my SB before with 0 success  |
eyetzr  Samba Member
Joined: October 09, 2013 Posts: 1473 Location: Toronto, Ontario. Canada
Posted: Tue Jan 21, 2014 4:26 pm Post subject: |
| You will have to use laminate glass for this. You cannot cut tempered glass, it will shatter. Laminate glass on door windows is a no no, just in case someone needs to get you out of the car in an emergency. You can use it behind the driver. I found new glass through my local glass shop. Good luck |
