summer samba Samba Member
Posted: Tue Feb 25, 2014 4:03 pm Post subject: front shock bump stops shorter |
Can I use the shorter carat front shock bump stops on a standard suspension? |
Jeff's Old Volks Home Samba Member
Joined: December 19, 2011 Posts: 819 Location: Chester Basin, Nova Scotia
Posted: Wed Feb 26, 2014 3:39 am Post subject: |
Shorter? Are you sure they're different? There would be no reason you can't.
Jeff _________________ www.jeffsoldvolkshome.com
2004 Jetta TDi Wagon
2002 Smyth Ute TDi
1990 Vanagon weekender Syncro AAZ
1987 Syncro Doka AAZ...soon to be TDI
2014 DL650ABS Xpedition
1986 Weekender Syncro (Under construction)
1987 Westfalia (Under construction)
1987 Syncro Single cab |
tpinthepack Samba Member
Joined: July 11, 2004 Posts: 849 Location: clearwater,florida
Posted: Wed Feb 26, 2014 3:54 am Post subject: |
I have never done this, but it has been well covered here many times. You can simply cut rings away from the existing bump stops. Look at the sticky's or search a little and you will see.
Tony _________________ TP in the Pack (I am a cyclist)
1968 Manx N.O.S. w/ Barrett Chassis
1960 Single Cab 1914 w/ 40 DLRA's
1990 Vanagon DOKA
1972 Super Beetle
1979 Super Beetle Convertible
2011 Porsche Cayenne |
Posted: Wed Feb 26, 2014 4:10 am Post subject: |
I've cut lots of them... I just didn't know VW sold a shorter one. I should pay closer attention I guess.
Jeff. _________________ www.jeffsoldvolkshome.com
2002 Smyth Ute TDi
insyncro Banned
Posted: Wed Feb 26, 2014 5:59 am Post subject: |
Jeff's Old Volks Home wrote: |
Jeff. |
Carats have less and Syncros have more rings than the GL bumpstops. |
Posted: Wed Feb 26, 2014 6:14 am Post subject: |
insyncro wrote: |
Jeff. |
Who knew!
By the way, I'm driving through New York next month if you need anything I could meet you somewhere...
2002 Smyth Ute TDi
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5930 Location: Tsawwassen, BC
Posted: Sat Mar 01, 2014 7:30 pm Post subject: |
thanks |
regis101 Samba Member
Joined: July 28, 2005 Posts: 2078 Location: Livermore, Ca
Posted: Sat Mar 01, 2014 8:50 pm Post subject: |
This was brought up before.
I'm thinking that all US bump stops had the same number of rings.
European models had shorter stops.
I picked up some carat springs along with the stops, spacers and discs from the same vehicle. the bump stops were the same size as the OE 85's.
I'll check back in the search _________________ Peace, ~R |
