Drivers seat slides a bit when braking
imikeh
imikeh is offline
PostPosted: Wed Apr 02, 2014 8:32 am    Post subject: Drivers seat slides a bit when braking Reply with quote
Hi all I have noticed that my drivers seat seems to slide forward a bit when I brake. Its just a tiny bit but I don't want it to get worse. Any ideas on the fix if needed?
imikeh
imikeh is offline
PostPosted: Wed Apr 02, 2014 6:26 pm    Post subject: Reply with quote
bump
tpinthepack
tpinthepack is offline
PostPosted: Wed Apr 02, 2014 6:32 pm    Post subject: Reply with quote
Non swivel base? Pull the seat out and make sure it has one of the plastic guides there. The guide does make it much tighter. You may be missing it. I only have 1 guide on each seat and I believe that is how it came new.
Tony
TP in the Pack (I am a cyclist)
1968 Manx N.O.S. w/ Barrett Chassis
1960 Single Cab 1914 w/ 40 DLRA's
1990 Vanagon DOKA
1972 Super Beetle
1979 Super Beetle Convertible
2011 Porsche Cayenne
imikeh
imikeh is offline
PostPosted: Thu Apr 03, 2014 11:00 am    Post subject: Reply with quote
yep nonswivel I will check for plastic guides. Is this the part that I should be looking for?
http://www.van-cafe.com/home/van_1396548112810/page_901
MarkWard
MarkWard is offline
PostPosted: Thu Apr 03, 2014 12:37 pm    Post subject: Reply with quote
Those will keep it from rocking, but if the seat is actually moving, it sounds like the lock rod is not engaging the tracks properly. It is an extremely basic design. Ours came with only one guide per side as well.
rmcd
rmcd is offline
PostPosted: Thu Apr 03, 2014 2:54 pm    Post subject: Reply with quote
I'm having same issue with both my seats. Driver is a transplanted eurovan seat and the passenger is a transplant Ed swivel seat with a eurovan chair. Neither have the plastic piece show above.
Did it fix yours?
VW LT40 build. Like a Vanagon but 30% larger in every direction and 40% slower even in metric.
https://www.thesamba.com/vw/forum/viewtopic.php?t=749359&highlight=
casimoto
casimoto is offline
PostPosted: Thu Apr 03, 2014 8:46 pm    Post subject: Reply with quote
Same prob here.
imikeh
imikeh is offline
PostPosted: Wed Apr 23, 2014 5:15 pm    Post subject: Reply with quote
got new plastic slide for drivers side. Replaced original with new one. Orignal was on drivers side near door.
Result- No difference.
rmcd
rmcd is offline
PostPosted: Sat Apr 26, 2014 8:49 am    Post subject: Reply with quote
I filed a square edge into the bar. I didn't want to take off a lot. It holds a little better. Others must have this issue?
Merian
Merian is offline
PostPosted: Mon Apr 28, 2014 6:54 pm    Post subject: Reply with quote
I have a similar issue. Mine are swivel seats in a Westy and the seat slews sideways on hard cornering. Very exciting. I'd love to hear of a fix.
