Roof soop??
BajaOrBust
BajaOrBust is offline
PostPosted: Wed Apr 30, 2014 4:06 pm    Post subject: Roof soop?? Reply with quote
I'm looking at getting an external oil cooler and want Use a roof scoop for it. Every scoop I see says I need a" small Oil cooler" but I don't exactly know what size small actually is. I can get a cooler from work with a thermostat and everything for 60 bucks but I'm not sure if it's too large, the dimensions are 7.5 x 12.5 inches and 3/4 inch thick. Is that too large? If it is, what are some alternative mounting locations for the cooler?
Axitech
Axitech is offline
PostPosted: Wed Apr 30, 2014 4:28 pm    Post subject: Reply with quote
If you put an external cooler on, you absolutely need to put in a thermostatically controlled diverter valve too! With one, no cooler is too big. It will simply cool the oil and when it gets too cool, it will divert it past the cooler. Without it, your oil may never reach operating temps and that is horrible. Acids and corrosive laced water forms in oil that never gets warmed up.
He said to them, “But now if you have a purse, take it, and also a bag; and if you don’t have a sword, sell your cloak and buy one. Luke 22:36
The strongest reason for the people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government.-Thomas Jefferson
BajaOrBust
PostPosted: Wed Apr 30, 2014 7:09 pm    Post subject: Reply with quote
Yeah the kit I can get from work has the thermostat divider, I just don't know if that cooler will fit in a roof scoop
KrAzY-BaJa
KrAzY-BaJa is offline
PostPosted: Wed Apr 30, 2014 7:23 pm    Post subject: Reply with quote
the scoops need like a 4x10" ? something like that its pretty small. I
mounted mine up on the firewall , similar size to what you have
70% of what you buy is something to start with.
ForYotaWagen: A Ford/Toyota/Volkswagen http://www.thesamba.com/vw/forum/viewtopic.php?p=4871576&highlight=#4871576
BajaOrBust
PostPosted: Wed Apr 30, 2014 7:48 pm    Post subject: Reply with quote
Doesn't the rising heat from the engine kind of defeat the purpose though if you're on the firewall?
BajaPete69
BajaPete69 is offline
PostPosted: Wed Apr 30, 2014 8:55 pm    Post subject: Reply with quote
Empi makes a cooler that for that scoop. I believe its part number 9271, couldnt find it in the online catalog though, try contacting them.
http://www.facebook.com/pedrodelnorte
BajaOrBust
PostPosted: Wed Apr 30, 2014 10:38 pm    Post subject: Reply with quote
Yeah I've seen it in a kit but it's cheaper for me to get the scoop and the cooler from work. But I guess it looks like I have to have that particular cooler.
Vanapplebomb
Vanapplebomb is offline
PostPosted: Mon May 05, 2014 8:17 am    Post subject: Reply with quote
Why do you need an external oil cooler?
What kind of fan shroud do you have?
How big is your engine?
Are your oil temps getting to high?
If you have a dog house fan shroud, an engine that is 2l or less, but your oil temps are high, just take some compressed air and blow out the fins of your oil cooler. Then your oil cooler will work fine and your oil temps will be happy.
Simple as that.
Don't make this more complicated than it has to be.
All this talk of external oil coolers is nice and all, but the truth is that they are rarely ever needed. People make more problems when they try to solve a problem that doesn't exist in the first place. In other words, adding external oil coolers can actually be a downgrade.
1800 Type 4 Berrien 295
Multi69s
Multi69s is offline
PostPosted: Tue May 06, 2014 11:52 pm    Post subject: Reply with quote
My Baja has a mild 2010 and I am running a 5-rib trans (4:86 gearing). What I did to get a little more oil cooling it to use the cooler from a T4. It is about a 3rd larger then the T1. The only work that is required is to get some sheet metal and widen the area of the doghouse where the cooler slips into it. I definitely noticed lower oil temps, and the only time that I might need a little more is when I am flogging it down the freeways when it is 100 degrees outside.
69 road Bug 2110
73 Squareback - 2L, T4, Automatic W/ AC
Gone, but many fond memories 69 Baja Bug 2010 - 5 Rib Bus Transaxle
Gone but not forgotten 72 Baja Bug 2010
My builds
T4 into Squareback http://www.thesamba.com/vw/forum/viewtopic.php?t=458944&highlight=
Auto Trans Rebuild http://www.thesamba.com/vw/forum/viewtopic.php?t=516066&highlight=
AC in Squareback https://www.thesamba.com/vw/forum/viewtopic.php?t=...highlight=
BajaOrBust
PostPosted: Sat May 10, 2014 1:57 am    Post subject: Reply with quote
Simple as that.
I'm building a 2180 and I live in southern california where the summers are not too cool and neither is the desert which is why I'm looking into the external coolers. Previously, my oil temps were screaming and I'm hoping to fix that problem and run as cool as possible.
utahclaimjumper
utahclaimjumper is offline
PostPosted: Sat May 10, 2014 6:07 am    Post subject: Reply with quote
I've used mine in all kinds of weather and temps, the external cooler is mounted in front of the fan air inlet, works great and not open to damage.>>>Dan
Brian
Brian is offline
PostPosted: Sat May 10, 2014 9:43 am    Post subject: Reply with quote
yee olde method to wearing down engine life.
I've driven through all of san Diego and and east on the s22 with no external and have been fine all year round. my 1641 is a tad smaller, but all you need is a doghouse cooler.
Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter
utahclaimjumper
PostPosted: Sun May 11, 2014 1:22 pm    Post subject: Reply with quote
Another country heard from, but "old school" has been around for a long long time.>>>Dan (And so has this engine)
tripicana
tripicana is offline
PostPosted: Mon May 12, 2014 11:14 am    Post subject: Reply with quote
Roof is a terrible place for oil cooler. Not only the line restriction in the hoses to reach it, branches can snag it, and you're screwed of you ever do roll it.
foam cowboy hats aren't good helmets.
dustymojave
dustymojave is offline
PostPosted: Mon May 12, 2014 1:06 pm    Post subject: Reply with quote
In the Sandy Eggo area where BajaOrBust lives and even in the surrounding mountains, and especially out in the not too far away deserts of SoCal, branches really are NOT an issue for roof scoops. In Tennessee or Michigan or other points east or way north in Oregon-Washington...YEAH!
Rollovers...Then a roofscoop cooler is a potential issue anywhere. I've had a cooler under the back window of my Baja for 4 decades. Never been a problem. But then I operate under the philosophy that "inverted operation is prohibited". I tested my Bug inverted BEFORE it was converted to a Baja. Embarassed But not since. Laughing I've seen coolers smashed under the rear window in a rollover as well as roof top mount. But it's less likely.
Mounting a VW oil cooler under the rear package shelf/above the trans gets virtually 0 air flow and is subject to rocks, mud and other debris getting kicked up.
Mounting it over the fan shroud intake pre-heats the air to the cylinders and increases cylinder temps noticeably. not a big issue for cooler climates than SoCal. But my personal experience here is that it's not a good location. for instance, our forecast for this week is for temps to reach triple digits in many of the urban areas. And it's the middle of May.
For an offroad only car, it's good to mount a cooler in the back of the cockpit to the roll cage where air coming through window openings with no glass cools the oil.
In a Class 11 style Bug or a street full body Bug, the vents under the back window provide virtually ALL of the cooling air into the engine compartment. So for that sort of Bug, I don't recommend mounting a cooler under the rear window for the same reasons as mounting it on the fan shroud intake.
But a Baja Bug gets air swirling around the back of the car and really very little of the cooling air going into the fan passes through those vents under the window. Especially if the sheet metal under the firewall and the inner fender panels behind the firewall are removed.
For a mostly stock 1600, a "Doghouse" cooler is fine by itself without additional external cooler.
For ANY air-cooled VW, I recommend AGAINST using the early style STEEL cooler inside the fan shroud that air blows through on the way to the #3 and 4 cylinders. But a later style "doghouse" ALUMINUM cooler that is inside the fan shroud, but the air passes through it and then out without passing over cylinders is GREAT!
A LOT of people these days are calling the whole fan shroud a "doghouse". That is VERY WRONG!!!!!!
The "doghouse" is just like the name says, a smaller house in the back of the main house (fanshroud). This style of cooler and shroud were installed by VW from 1971-on. Many other VWs have had aftermarket "doghouse" shrouds and coolers installed or had the original replaced with a doghouse from a later Bug.
For BajaOrBust with a 2180 and apparently a fair amount of street use in SoCal, I recommend a Doghouse cooler, plus a full-flow under the rear window or in a roof scoop.
Way back in the 1980s, Tom and Bob Neth who are well-known fabricators from the North-County area had a 5-1600 Baja with a cooler mounted inside the rear part of the roof. It was boxed away from the interior with sheet aluminum and it had NACA ducts in the roof for air intake and outlet. Probably the slickest setup yet on a Baja Bug. I've never seen it duplicated.
Richard
SoCalBajas Member
dustymojave
PostPosted: Mon May 12, 2014 1:14 pm    Post subject: Reply with quote
It's kinda surprising that nobody has mentioned it before but I'm sure we all understood that BajaOrBust intended the title of this thread to read "Roof Scoop". But if you roll the car over on a cooler inside of a roof scoop, you're liable to wind up with "roof soup".
Richard
SoCalBajas Member
Brian
Brian is offline
PostPosted: Mon May 12, 2014 5:31 pm    Post subject: Reply with quote
dog house cooler setup from Mr. Bill:
you could use this as a jerry-rig cabin heater Laughing
Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter
