AC spade connector
PAPI
PAPI is offline
PostPosted: Sat Jun 14, 2014 10:25 am    Post subject: AC spade connector Reply with quote
Installing new speakers in the rear - noticed this wire broke(?) free from the AC spade connector. (right side as you face the unit) As far as I knew, the AC was working OK- any thoughts? Thanks!
vanis13
vanis13 is offline
PostPosted: Sat Jun 14, 2014 12:51 pm    Post subject: Reply with quote
if I recall, that is the temp sensor so if the evap starts to freeze it cuts out the compressor. easy fix - replace that one spade (or take it out and recrimp this wire to the single spade) - cheaper than a new compressor or hose which could burst if unit frozen.
denwood
denwood is offline
PostPosted: Sat Jun 14, 2014 6:01 pm    Post subject: Reply with quote
Bursting is not an issue. The high pressure AC switch would cut the compressor (by design) well before burst pressure.
Cheers,
Dennis Wood
The Grape
