Chad Traylor Samba Member
Joined: September 16, 2013 Posts: 5 Location: Lexington Ky
Posted: Sat Jun 14, 2014 1:24 pm Post subject: New wiring harness turn signal problem |
| I have a Wiring Werks harness and WW flasher that I just put in my 12v 1960 sc. I dont have an emergency flasher. Ive searched the forum over and haven't found the same exact problem addressed. Front turn signals work fine along with the indicator light on the speedo. Problem is both of the rear signals flash when signaling left or right. I don't think its a turn signal switch issue. After unhooking the turn signal switch, a hot wire attached to the black &yellow wire on the harness gets both rear lights on. Hot wire to the black& red wire on the harness gets both lights illuminated also. Any help or solutions would be greatly appreciated. |
SambaUser1M Samba Member
Joined: October 27, 2012 Posts: 135 Location: Irvine, CA
Posted: Sat Jun 14, 2014 4:30 pm Post subject: |
| It sounds like your bk/rd wire is shorted to your bk/yw wire. If not "shorted", per se, they're connected to each other somewhere. |
Posted: Sat Jun 14, 2014 6:13 pm Post subject: |
| I ran a couple wires bypassing the wiring harness. I got the same results with the rear turn signals. I now suspect the hose clamp technique I used for grounding the rear tailights may be the culprit. |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 26388 Location: Olympia Wash Rinse & Repeat
Posted: Sat Jun 14, 2014 9:19 pm Post subject: |
Add a ground wire from each taillight and run them to the battery neg cable grounding point on the body.
VW finally did this at the factory starting about 1970 due to this problem.... _________________ In Stereo, Where Available! |
