-Rusted_Radio- Samba Member
Joined: October 14, 2003 Posts: 246 Location: Siloam Springs,Ar
Posted: Sun Aug 03, 2014 10:27 am Post subject: Head match porting, and transmission diffrentes |
So I have made is this far with a dremel burr. I don't have a die grinder. But don't think dremel makes longer bits.
What stages of bits do you use.
Tube burr
Cone burr
Also I have found a replacement transmission IRS but not sure if it will work. Only diffrance I found was the two drains rather than one drain.
_________________ Wes
61 Beetle on 69 Frame
Siloam Springs, Ar
Last edited by -Rusted_Radio- on Sun Aug 03, 2014 11:32 am; edited 1 time in total |
mcmscott Samba Member
Joined: March 12, 2010 Posts: 4946 Location: sanger ca
Posted: Sun Aug 03, 2014 11:21 am Post subject: |
2 drains mean it is a 69 model trans, probably start with "AH" code. Also has early pinion bearing. 70 model started 1 drain plug, late pinion bearing, and early crosshaft, the ratios are the same. 4.12 r/p with 3.8, 2.06, 1.26, ,89 stack _________________ There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250 |
Posted: Sun Aug 03, 2014 11:36 am Post subject: |
Mcmscott thanks for reply but you should have smacked me and told me to go back to the car port. So I've already swapped nose cones from the 1 drain tranny to the two drain. Forgot the years you just told me. The front mounts were broke. Then went to swap throw outs and had the light bulb whoa yea there different.
Will swapping nose cones make an issue. I will have to get a new throw out bearing now. But will the nose cones be ok. Hockey sticks seam to be the same. _________________ Wes
Siloam Springs, Ar |
Posted: Sun Aug 03, 2014 12:25 pm Post subject: |
If the m/s bearings are the same then you are ok, if not you need to clearence the nose cone _________________ There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250 |
Posted: Sun Aug 03, 2014 1:20 pm Post subject: |
M/S bearing?
Tranny code IRS AH1610345
AH 1500 4.125 IRS suspension from 8/68
AH 1600 4.125 8/69-8/72
Main spline shaft has back and forth play in it. _________________ Wes
modok Samba Member
Joined: October 30, 2009 Posts: 27754 Location: Colorado Springs
Posted: Sun Aug 03, 2014 1:39 pm Post subject: |
The dremel company did not make carbide burrs, now they make only small 1/8 diameter one piece ones, which are junk IMO. They break too easy.
Other companies make longer carbide burrs with steel shank and about 1/4" carbide heads. They work great. I've had two of them that have lasted about four dremels. I think dremel sees no profit margin in selling things that never wear out.
The cheap 2 speed dremel is not QUITE powerful enough to run a 1/4" burr but I run them on 160 volts with a variac. That perks em' up. |
Danwvw Samba Member
Joined: July 31, 2012 Posts: 8895 Location: Oregon Coast
Posted: Sun Aug 03, 2014 1:58 pm Post subject: |
"modok" your a bit of a wild man! 160 Volts on a Dremel Motor!
There is another option on the transaxle that involves getting this kit!
_________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
Posted: Sun Aug 03, 2014 4:41 pm Post subject: |
Thanks for the links I should have made this two topics but...I didn't. Well I figure I'm going to look for a different transmission. Now that I'm in a pickle I don't have money to swap bearing or clutch parts. But I sure didn't know someone makes an in between kit. Also didn't know about the plates, I knew there were different bearings.
Off to find some bits and a free transmission _________________ Wes
Posted: Sun Aug 03, 2014 6:35 pm Post subject: |
Could I use a super beetle transmisson, in a 69 frame? I've heard there's an adapter but I haven't found one. _________________ Wes
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15604 Location: Deep in the 405
Posted: Sun Aug 03, 2014 7:28 pm Post subject: |
Super Beetles used the same transaxle and all the regular Bugs. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
