viiking Samba Member
Joined: May 10, 2013 Posts: 3146 Location: Sydney Australia
Posted: Fri Oct 24, 2014 3:10 am Post subject: 12v Bosch Wiper Motor overhaul |
There are 3 electrical contact arms in the gearbox of my Bosch 12V wiper motor. I have researched how to overhaul the motor and all say that you have to refill the gearbox with grease. In doing so the contacts seem to get covered in grease.
Do you fill the gearbox completely? Do the contacts have to be completely clean and the gear as well?
I can't see how you can achieve both without reducing the amount of grease in the gearbox.
Any help gratefully accepted. |
williamM Samba Member
Joined: August 07, 2008 Posts: 4342 Location: southwest Arizona
Posted: Fri Oct 24, 2014 6:31 am Post subject: |
use light grease not blue marine grease- the spring loaded contacts will find a way. _________________ some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any! |
Posted: Fri Oct 24, 2014 1:11 pm Post subject: |
Thanks William!
So light grease, like for chassis lubrication? Not lithium or extreme pressure wheel bearing grease? |
Posted: Fri Oct 24, 2014 6:39 pm Post subject: |
about the consistency of petroleum jelly- there are some good synthetics available that wont get waxy in a few years.
Then if you want to play with the brushes you need the magic brush retainer tool
[img][/img] _________________ some days I get up and just sit and think. Some days I just sit.
