Fuel Tank Removal
prevailion
prevailion is offline
PostPosted: Sun Nov 16, 2014 8:59 pm    Post subject: Fuel Tank Removal Reply with quote
I was wondering how you can remove a tank without dropping the engine. I need to replace mine in my 1978 bay window automatic bus. Its fuel injected. I've seen it done and was wondering if it would be easier because i don't have a lift and many tools to remove the pancake engine.
1967250s
1967250s is offline
PostPosted: Sun Nov 16, 2014 10:02 pm    Post subject: Reply with quote
It can be done. I've stripped my engine down to a short block and changed pistons, while still mounted. You just have to get everything out of the way of the fuel tank and be ready to crawl over the engine to get all the connections. If you can't get in-fit inside- the engine hatch, not a good idea. Don't expect it to be easy, you may have to remove much of the FI stuff and the front tin, top and fan house to get it out.
aeromech
aeromech is offline
PostPosted: Mon Nov 17, 2014 9:25 am    Post subject: Reply with quote
The border patrol did it and so can you.
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
jtauxe Premium Member
jtauxe is offline
PostPosted: Mon Nov 17, 2014 9:40 am    Post subject: Reply with quote
BTW, don't install it back the way that it was done in the preceding photos. Having those steel cables rubbing against the steel tank with no padding for protection is a bad idea. Use some of those heavy felt pads that you can get for furniture to protect floors. They are adhesive on one side, making installation easy.
John
http://vw.tauxe.net
1979 Champagne Sunroof, 1974 Westfalia Automatic, 1979 Transporter, 1972 Sportsmobile, 1973 Transporter Wild Westerner, 1974 Westfalia parts bus
, 1975 Mexican single cab *FOR SALE*, 1978 Irish 4-door double cab RHD
Tcash
Tcash is offline
PostPosted: Mon Nov 17, 2014 9:46 am    Post subject: Reply with quote
This guy did it.
http://www.thesamba.com/vw/forum/album_page.php?pic_id=1216459
Search his post.
merlinj79
merlinj79 is offline
PostPosted: Mon Nov 17, 2014 9:52 am    Post subject: Reply with quote
In the grand scheme of things it will probably be easier to drop the motor first.
It can be done with a cheap floor jack and some plywood, although a motorcycle jack is even better. It can be done solo, but better to have a helper. You only need the helper for about five minutes each dropping and installing, and he/she doesn't need skills.
Rick
"Pumpkin II"
Stock 2L FI '77 Westy
CA Smog Stuff
