Where did this spacer come from?
Henrik_K
Henrik_K is offline
PostPosted: Thu Dec 25, 2014 12:11 pm    Post subject: Where did this spacer come from? Reply with quote
Turned my Type4 - 1800 - shortblock around in the enginestand today.
This little bugger fell out. It's kind of shivered - with an odd pattern on it. It definitely doesn't looks like a regular spacer...
Can anyone identify where this might come from?
Thanks
raygreenwood
raygreenwood is offline
PostPosted: Thu Dec 25, 2014 12:24 pm    Post subject: Reply with quote
Cant tell from the photo. What are the specs/size? ID, OD, thickness?
Ray
Tcash
Tcash is offline
PostPosted: Thu Dec 25, 2014 3:01 pm    Post subject: Reply with quote
Thanks to jerseylooker
Did you take #8 the Distributor drive out?
[url]
Good luck
Tcash
[/url]
SGKent Premium Member
SGKent is offline
PostPosted: Thu Dec 25, 2014 3:05 pm    Post subject: Reply with quote
yes - that is the shim under the distributor drive gear. It will have 3 worn/shiny high spots on each side. Don't lose it.
George Carlin:
Skills@EuroCarsPlus:
1971 deluxe (sold)
1977 deluxe
raygreenwood
PostPosted: Thu Dec 25, 2014 5:04 pm    Post subject: Reply with quote
Laughing thats what I get for looking at this on my phone. As good as my 5s screen is.....I could not see the three telltale nubs of the distributor drive shim. My eyes may also be getting old....just the eyes.
Ray
Henrik_K
Henrik_K is offline
PostPosted: Fri Dec 26, 2014 1:08 am    Post subject: Reply with quote
Yes, I did take the distributor drive gear out, cause I thought it pointed in the wrong direction when #1 was at TDC.
How do I get back in? a little grease on the end of drive gear?
Should it be flipped in a specific way?
Thanks a lot....
williamM
williamM is offline
PostPosted: Fri Dec 26, 2014 1:32 am    Post subject: Reply with quote
Best way to return it is to spear it with long skinny screwdriver and slide it down the hole, grease will help hold it in place ti the drive comes back on top.
some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any!
Wasted youth
Wasted youth is offline
PostPosted: Fri Dec 26, 2014 3:43 am    Post subject: Reply with quote
Are these readily available?
Is this the part number> 021105235 ??
Tcash
Tcash is offline
PostPosted: Fri Dec 26, 2014 4:05 am    Post subject: Reply with quote
A screwdriver is best. Less chance of dropping the washer.
No, either way will work.
Thanks a lot....
Indexing Distributor Drive Pinion
Henrik_K
Henrik_K is offline
PostPosted: Fri Dec 26, 2014 5:15 am    Post subject: Reply with quote
Thanks Guys....
SGKent is offline
PostPosted: Fri Dec 26, 2014 8:20 am    Post subject: Reply with quote
as stated, grease on it and a long skinny rod ir screwdriver. Put the it on the screwdriver and make sure you have it. Put the screwdriver all the way down in the bearing race before you let the washer slide down. Use a dowel or snap ring pliers to grasp the gear as you put it in. Do not remove the gear again because if that washer had fallen into the engine you would be disassembling it now to get it out. If you have to turn the gear, only pull it out enough where the teeth disengage - leave the tail in the bearing race. You were really lucky this time. Don't forget the spring when you put the distributor back in.
George Carlin:
1971 deluxe (sold)
1977 deluxe
Henrik_K
Henrik_K is offline
PostPosted: Fri Dec 26, 2014 9:58 am    Post subject: Reply with quote
Thanks again....
I have the engine in the engine stand. I could rotate the engine upside-down and that way insert the piniongear with the shims on?
I wasn't aware that the shims could slide into the engine like that.
Lucky that it came out and that I actually noticed this.
Otherwise I might just have overseen it on the floor...
Thanks again for all your repsonse. Appreciate it.
Merry X-mas and all...
Tcash
Tcash is offline
PostPosted: Fri Dec 26, 2014 10:07 am    Post subject: Tom Wilson Reply with quote
Might I suggest you purchase this book.
How to Rebuild Your Volkswagen air-Cooled Engine - Tom Wilson
Publisher Penguin, 1987. ISBN 0895862255, 9780895862259
It describes in great detail all the steps of rebuilding a air cooled VW engine. Read and understand it completely. Don't be afraid to ask questions.
Good Luck
Tcash
williamM
williamM is offline
PostPosted: Sat Dec 27, 2014 1:42 am    Post subject: Reply with quote
Just in case the T-1 engine new guys are listening- you can not put your bigger stack of washers on your drive and put them in - your thrust washers must be in the case first - then the drive installed as the washers will gouge the brass crank gear and NOT allow the drive to engage the crank gear. Embarassed Embarassed Embarassed
Don't step in any!
Henrik_K
Henrik_K is offline
PostPosted: Sat Dec 27, 2014 2:05 pm    Post subject: Reply with quote
I actually have this book and others. But as English is not my first language - it can difficult the read and understand tech stuff.
I also have the BugMe videos...
Tcash
Tcash is offline
PostPosted: Fri Mar 20, 2015 8:43 am    Post subject: Re: Tom Wilson How to Rebuild Your Volkswagen air-Cooled Eng Reply with quote
Tcash wrote:
Might I suggest you purchase this book. It describes in great detail all the steps of rebuilding a air cooled VW engine. Read and understand it completely. Don't be afraid to ask questions.
Good Luck
Tcash
ROCKOROD71
ROCKOROD71 is offline
PostPosted: Fri Mar 20, 2015 9:16 am    Post subject: Reply with quote
http://www.busdepot.com/021105235
Whether or not they have it in stock is another story...
1971 STD BEETLE- DD-1st car, 1st love. keepin' it stock! 1600DP, Solex 34-3 Mexi Bosch SVDA Dist NOW w/POINTS
1977 WESTY "KrustyKamper" 2L FI
79SuperVert wrote:
30 years from now, the next guy may not want your girlfriend, but he may want your classic car, depending on how nice you were to it.
asiab3 wrote:
Careful guys, a petulant child can grow up to be president these days.
**winter drivers: no survivors!**rust warrior**#keepbodyshopsbusy**
photoboy52
photoboy52 is offline
PostPosted: Fri Mar 20, 2015 9:25 am    Post subject: Re: Tom Wilson How to Rebuild Your Volkswagen air-Cooled Eng Reply with quote
Tcash wrote:
Good Luck
Tcash
This book is so great, worth its weight by far, I purchased an extra at a thrift store the other day, can leave this one in the bus, it was a steal for $2! Smile
Current
1972 Sierra Yellow Campmobile
1.7L (rebuilding)
'97 Geo Metro 3 door 1L
Tin can on a skate Very Happy
(Did engine rebuild my self)
Past
1961 Bug Sedan
Thrown Rod (Recently found it still at home now need to get from Nor Cali to SE TX!!)
Tcash
Tcash is offline
PostPosted: Wed Mar 23, 2016 6:56 pm    Post subject: Tom Wilson Reply with quote
Good Luck
Tcash
