Mounting Pertronix Ignitor II in 009
Henrik_K
Henrik_K is offline
PostPosted: Sun Jan 25, 2015 1:28 pm    Post subject: Mounting Pertronix Ignitor II in 009 Reply with quote
Tried to fix my Ignitor II module in my new 009 distributor today.
According to the instructions the plastic ring should be to gently forced down over the distributor axel.
Somehow this doesn't apply with my ring. I've tried tapping with rubber mallet - not using brute force though - but it wont.
Should I just use a bigger hammer or?
Thanks...
Tcash
Tcash is offline
PostPosted: Sun Jan 25, 2015 1:47 pm    Post subject: Reply with quote
What are the numbers on the Ignitor II package?
airschooled
Air-Schooled
airschooled is offline
PostPosted: Sun Jan 25, 2015 9:30 pm    Post subject: Reply with quote
Make sure it's lined up; turn it slightly as your push down. Mine was an extremely tight fit. I destroyed it when I removed it with screwdrivers months later. I think I may have even had to razor-chamfer a bevel to the edge of the plastic ring.
www.airschooled.com
Henrik_K
Henrik_K is offline
PostPosted: Mon Jan 26, 2015 2:23 am    Post subject: Reply with quote
I've bought this package:
http://www.ebay.com/itm/331084156890?item=331084156890&viewitem=&vxp=mtr
Tcash
Tcash is offline
PostPosted: Mon Jan 26, 2015 9:12 am    Post subject: Reply with quote
Problem is, they make these for a lot of different distributors. You need the part number off the box to make sure you received the correct one.
I have run across the Magnet Sleeve being tight. But not to the point it requires hammering it on.
You may need to contact Pertronix.com and see if they will send you another Magnet Sleeve.
Good Luck
Tcash
Henrik_K
Henrik_K is offline
PostPosted: Mon Jan 26, 2015 12:25 pm    Post subject: Reply with quote
Just found the box, it says "91847A" - and should fit 009 Distributor...
Besides that - the magnet sleeve feels a little loose like it doesn't fit the square on the axel 100%..
Bought it from KMJ Performance, Maybe I should ask them if they got one fits more precise...
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Mon Jan 26, 2015 12:27 pm    Post subject: Reply with quote
http://pertronix.com/support/
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
