Grr. throttle cable snapped near bell crank. repair/replace?
newfisher
newfisher is offline
PostPosted: Thu Feb 05, 2015 10:32 pm    Post subject: Grr. throttle cable snapped near bell crank. repair/replace? Reply with quote
Snapped about 5 inches from the bell crank. Should I compression clamp it on both sides with a stainless splint round stock or replace the cable? Whats the flat rate time on a cable R/R?
newfisher
PostPosted: Thu Feb 05, 2015 11:13 pm    Post subject: Reply with quote
Just remembered the air cooled type 1 throttle cable repair kits! Gonna hit the parts store at lunch and order a new cable as a back up. Cant believe I forgot about that one. Maybe ill pick up a roller pedal while im there hahaha
syncrodoka
syncrodoka is offline
PostPosted: Thu Feb 05, 2015 11:33 pm    Post subject: Reply with quote
I would buy a new vanagon throttle cable and not mess around with a repair kit if possible.
I make it a habit of replacing them when I get a car and they are often frayed inside the housing towards the back, I had one that was hanging on by a single strand or 2.
Attach a long piece of wire to the cable at the engine side to help pull the new one back into place. There is a bolt attaching it to a frame rail just in front of the passenger side rear tire and the cable is installed forward and back to the engine from there.
They are pretty easy to replace.
the joker
the joker is offline
PostPosted: Fri Feb 06, 2015 6:27 am    Post subject: Reply with quote
buy two Wink stow one as a spare
simple stuff like that can leave you stranded Rolling Eyes
repair kit
the joker
PostPosted: Fri Feb 06, 2015 6:29 am    Post subject: Reply with quote
repair kit ....... really ...... for a throttle cable
insyncro
Banned
insyncro is offline
PostPosted: Fri Feb 06, 2015 6:45 am    Post subject: Reply with quote
18 bucks for a new cable and about 18 minutes to install Wink
newfisher
PostPosted: Fri Feb 06, 2015 8:29 am    Post subject: Reply with quote
Pouring rain and wanting to get out of town for the weekend. Ill replace it next week.
Abscate Premium Member
Abscate is offline
PostPosted: Fri Feb 06, 2015 9:27 am    Post subject: Reply with quote
Thoughts from the marine side. Do these things break from chafe or from corrosion? If it is corrosion, could you just go SS for lifetime cables?
Captjon1959
Captjon1959 is offline
PostPosted: Fri Feb 06, 2015 10:09 am    Post subject: Reply with quote
I say just replace it. When I go my van I had it inspected and the shop considered the "spliced" throttle cable a safety hazard.
1984 Westfalia Wolfsburg Edition
Former 1.9 L now Bostig Ford Zetec
the joker
PostPosted: Fri Feb 06, 2015 10:16 am    Post subject: Reply with quote
pouring rain Shocked best time to break down for a $20 fix
years ago had to run the throttle(by hand from the back) while my wife did the driving 30 plus miles
never again always carry a spare Cool
Steve M.
Steve M. is offline
PostPosted: Fri Feb 06, 2015 12:35 pm    Post subject: Reply with quote
One of the first things I did buy was a spare throttle cable. It's an annoying to have one break in the middle of nowhere and not be able to fix it or wait a few days for the nearest parts store to get one.
Too many memories from my '68 bus!
insyncro
Banned
insyncro is offline
PostPosted: Fri Feb 06, 2015 1:38 pm    Post subject: Reply with quote
I had a Syncro's gas tank pinch the throttle cable when it was filled to the brim.
I rigged up a piece of fishing line, over a broomstick to creat the bend needed to get it up to the cabin, so I could drive it from the NY State Thurway to my shop and fix it right.
The look on the toll collectors face when I pulled the line and rev the engine...priceless Laughing
newfisher
PostPosted: Fri Feb 06, 2015 11:07 pm    Post subject: Reply with quote
Ordered a new cable, upon further DAYLIGHT investigation the suby conversion requires a spliced end. The cable failed at the splice. I have re engineered the splice and its now bomb proof. Barrel nuts, crimps, extra stainless cable are all included with my new spare cable in case it fails somewhere else. The sheath underneath looks clean and after pulling the front inspection cover under the throttle rod, it looks new. Confident I found the failure, checked the rest of the cable condition and am armed with anything needed down the road. Off on a road trip tomorrow!
syncrodoka
PostPosted: Fri Feb 06, 2015 11:49 pm    Post subject: Reply with quote
I would be interested in seeing a picture of what you are talking about. That doesn't sound like the standard setup that most people use.
Terry Kay
Banned
Terry Kay is offline
PostPosted: Fri Feb 06, 2015 11:57 pm    Post subject: Reply with quote
All sounds like a case of typical Petrolis Neglectus.
A little lubrication goes an awful long way on the belcrank under the floorboards, and the cable itself--one or twice every 100,000 miles or so--
T.K.
