sonnybug Samba Member
Joined: October 03, 2010 Posts: 96 Location: Madison, TN
Posted: Wed Mar 04, 2015 12:16 pm Post subject: Clutch questions, New clutch disk stuck to flywheel. |
| I'm finally getting around to installing a 2.0. While I was inspecting the clutch placement, I noticed that it was just a tad off center. My clutch alignment tool went in fine, but I wasn't completely happy. When I took off the pressure plate, the clutch disk wouldn't budge. It was a brand new disk that I installed about 2 months ago. When I say wouldn't budge, I definitely mean it. I didn't want to pry it out just yet, so the pressure plate was just bolted back up for now. What are you guys' opinions on this matter? According to my clutch tool, the alignment SHOULD be fine. Is my OCD getting the better of me? Will I be able to get that unstuck once it's running in the van? |
SGKent  Samba Member
Joined: October 30, 2007 Posts: 43009 Location: at the beach in Northern Wokistan
Posted: Wed Mar 04, 2015 12:37 pm Post subject: |
are you saying that you removed the pressure plate but the disk remained glued to the flywheel, or the pressure plate? _________________
Canned Water - the new California approved parts cleaner (except in a drought in which case rub it with sand).
George Carlin:
Skills@EuroCarsPlus:
"never time to do it right but always time to do it twice"
1971 deluxe (sold)
1977 deluxe |
Posted: Wed Mar 04, 2015 12:56 pm Post subject: |
| Flywheel. Sorry, I just realized I never said that. |
SGKent  Samba Member
Posted: Wed Mar 04, 2015 1:01 pm Post subject: |
| sonnybug wrote: |
Disk is glued to the flywheel? Is that what the problem is? _________________
George Carlin:
1971 deluxe (sold)
1977 deluxe |
Posted: Wed Mar 04, 2015 1:19 pm Post subject: |
| That and the fact that the clutch disk is slightly off center |
Tcash Samba Member
Joined: July 20, 2011 Posts: 12843 Location: San Jose, California, USA
Posted: Wed Mar 04, 2015 4:52 pm Post subject: |
To make your life easier. Remove the pressure plate and free up the disc now and center it.
It will make things go smoother when you put the engine in.
Good Luck
Tcash |
blue77bay Samba Member
Joined: February 11, 2006 Posts: 631 Location: Brisvegas Australia
Posted: Wed Mar 04, 2015 4:55 pm Post subject: |
pry it off ,resurface the flywheel and replace the disk,check the face of the PP as well if any hotspots are there just replace the lot _________________ I like hammers. Lots of hammers. Hammers and me go way back.
A large hammer collection is like an instant problem solver
Mark tucker wrote:,wack off as needed |
Tcash Samba Member
Posted: Wed Mar 04, 2015 6:19 pm Post subject: Re: Almost ready to instal motor-Clutch questions |
| sonnybug wrote: |
Posted: Wed Mar 04, 2015 6:28 pm Post subject: |
the disc might have been new 2 mths ago but what has transpired since , post some pics of the flywheel surface and the PP surface ,what has happened to cause it to stick so well ,either way pics are necessary _________________ I like hammers. Lots of hammers. Hammers and me go way back.
Tcash Samba Member
Posted: Wed Mar 04, 2015 6:50 pm Post subject: |
Maybe surface rust, causing it to stick?
Tcash |
old DKP driver Samba Member
Joined: March 30, 2005 Posts: 4143 Location: Los Gatos,Ca.
Posted: Wed Mar 04, 2015 6:57 pm Post subject: rusty disc |
X-2 Tcash since the engine has been sitting since December and We all know how moisture can be in the winter time.
TO the OP there are rivets that hold the clutch lining to the steel assembly
just like riveted brake shoes. moisture is attracted to the rivets and can't
escape.
Pull the disc and clean off the surface if possible or replace it if it leaves material stuck. Also, what type of pilot shaft are you using to align the disc? _________________ V.W.owner since 1967 |
Posted: Wed Mar 04, 2015 7:20 pm Post subject: |
The pilot shaft aligns the splines of the disc with the pilot bearing. You should be able to look through the splines and see that they are concentric around the bore of the bearing.
Your disc should pop loose pretty easy. Take a 2x4 and lay it against the metal hub of the disc and whack the board with a hammer and the disc should pop free. |
Posted: Sat Apr 04, 2015 9:47 am Post subject: |
| Im just tying up some old posts so if other people search, they'll see the problem washed closed out with the advise given...I was able to break the clutch loose with a good whack on the hub. The problem was a bit of surface rust developing. Cleaned the flywheel, installed clutch, engine in, clutch feels soooo good. |
Tcash Samba Member
Posted: Sat Apr 04, 2015 10:06 am Post subject: |
Thank you very much for following up. You would not think a new clutch disk would rust to the flywheel.
We do see this once in awhile, on buses that have been stored for a period of time.
Thanks
Tcash |
SGKent  Samba Member
Posted: Sat Apr 04, 2015 3:41 pm Post subject: |
| Tcash wrote: |
Thanks
Tcash |
keep the male dog away from the engine when you leave the garage. Just saying  _________________
George Carlin:
1971 deluxe (sold)
1977 deluxe |
