Stock Dometic fridge question in custom cabinet
Emmitt
Emmitt is offline
PostPosted: Fri Jun 12, 2015 2:11 pm    Post subject: Stock Dometic fridge question in custom cabinet Reply with quote
So I had gotten a free dometic fridge from a buddy for doing a job for him so I decided to put it in my vanagon. I made a custom cabinet for it. I was wondering how to wire up these to the stock wiring so I can get it to run on the alternator.
Im pretty sure I can tap into some wires to get this running normal I just didn't want it to kill the battery after I turned the key off, or can that just be bypassed by turning the switch propane or shore power when off?
1987 Synchro Vanagon GL "Passenger Van".
Boosting RG4, GoWesty Syncro 2in lift Springs, Custom Paint and Interior.
View user's profile Send private message Send e-mail Facebook Classifieds Feedback
spitsnrovers
spitsnrovers is offline
PostPosted: Fri Jun 12, 2015 5:01 pm    Post subject: Reply with quote
If you don't have the Bentley manual, check out the wiring diagram for the fridge here:
http://www.griffco.ca/interest/vw/vwfridgemods.htm
'88 VW Westfalia
'75 Triumph Spitfire 1500
Emmitt
Emmitt is offline
PostPosted: Fri Jun 12, 2015 5:33 pm    Post subject: Reply with quote
Thank you Ill see what I can rig up with that. I have it bookmarked.
DLJ
DLJ is offline
PostPosted: Sat Jun 13, 2015 10:49 am    Post subject: refrigerator Reply with quote
You can wire it up like VW did. Use a relay triggered by ignition. Turn key off, power to fridge is disconnected. Or install a simple toggle switch, but you will have to remember to switch off when parked.
Don't expect vert good cooling results from 12V. I would just go straight propane.
