Emergency brake/ rear brake adjustment help
Double7Westy
Double7Westy is offline
PostPosted: Tue Jun 23, 2015 2:57 pm    Post subject: Emergency brake/ rear brake adjustment help Reply with quote
I used the search function to try to get my answer to this question but didn't see anything with pictures or detailed steps and my bentley manual hasn't come in so I was hoping someone could help me as the idea of my bus rolling down the hill is less than appealing and Id like to fix it.
Basically I pull my handbrake all the way out and it still doesn't hold the whole bus. The general consensus i can see from searching is that the rear brakes need to be adjusted before doing this to get optimum results.
Anyone have any advice or pictures they could help me out with?
I was hoping I'd be able to tackle this issue in a couple hours tomorrow morning.
Thanks
SGKent Premium Member
SGKent is offline
PostPosted: Tue Jun 23, 2015 3:05 pm    Post subject: Reply with quote
adjust the rear brakes first and see if that helps.
George Carlin:
Skills@EuroCarsPlus:
Tom Powell
Tom Powell is offline
PostPosted: Tue Jun 23, 2015 3:26 pm    Post subject: Reply with quote
often the star adjusters need some TLC
Aloha
tp
busdaddy
busdaddy is online now
PostPosted: Tue Jun 23, 2015 3:27 pm    Post subject: Reply with quote
Adding the year of your bus as well as the model and any pertinant modifications to your signature line would make helping you much easier Wink
Слава Україні!
oscarsnapkin
oscarsnapkin is offline
PostPosted: Thu Jul 02, 2015 12:43 am    Post subject: Reply with quote
I'm having a similar problem. I replaced both brake cables, cleaned/lubed adjusters, adjusted brakes, adjusted cable tension, but still absolutely no parking brake whatsoever. There is some tension now when I pull the lever, but it does absolutely nothing as far as holding the Bus. The shoes that are on the Bus are old, but still have plenty of lining. Parking brake lever and spreader seem to be in working order. Any thoughts? It's a major PITA since my driveway is on an incline and I have to reach out the driver's door and place a chock behind the wheel while making sure my foot doesn't slip off the brake pedal. I grabbed this photo from one of Aeromech's posts. Is this the correct setup for a '77? I wanted to compare it to mine to make sure everything is installed properly. Thanks, and happy 4th.
- 1977 CEI Sunroof Bus 2.0L F.I. Hydraulic Lifters
- 1973 Thing
"It’s so easy to laugh, it’s so easy to hate, it takes strength to be gentle and kind."
jmstu76
jmstu76 is offline
PostPosted: Thu Jul 02, 2015 8:20 am    Post subject: Reply with quote
That is not a pic of a 77. That would be a 70 or earlier.
James
'76 Deluxe Sage Green Westy
2258 cc GD case 78mm CW crank, 2.0 H-beam rods 5,325” 22mm pin, JE forged pistons with 15cc dish, JE rings, type 11 clearanced oil pump, CB Eagle 2205 Type-2 “Torque Special” hydraulic cam with matched lifters fed by CB Dual Weber 40 IDF MX with 6” foam air filters, currently 55 idle, 130 main, 200 air correction, 32 mm venturis. 27in General Grabber AT2 All Terrains, Berg Shifter, stock '76 exhaust HPC Ceramic Coated. 11/18/2020
View user's profile Send private message Send e-mail Yahoo Messenger MSN Messenger Instagram Gallery Classifieds Feedback
1967250s
1967250s is offline
PostPosted: Thu Jul 02, 2015 10:50 am    Post subject: Reply with quote
Check the cables are not frozen in the rear tubes. Also, you may have to tighten up the cables up front, where they connect to the puller rods.
'72 Elm Green Deluxe
wihr
wihr is offline
PostPosted: Thu Jul 02, 2015 12:06 pm    Post subject: Reply with quote
What about the adjusters at the base of the arm inside the cabin ?
WIHR
1970 Campmobile "Van Ordinaire"
2009 Lincoln Town Car "Behemoth"
1969 Lambretta 150 DL "Nina"
1962 Matchless G 12 CS 650cc
mikedjames
mikedjames is offline
PostPosted: Thu Jul 02, 2015 1:08 pm    Post subject: Reply with quote
That rear hub picture looks like my late-73 bus . Or close enough.
The handbrake cable adjusters are under the front of the bus on later handbrakes.
The trick is to slacken the handbrake cables fully then adjust the star adjusters on the rear drums so the shoes are just touching (procedure in Bentley and other places) and then readjust the handbrake cables so the handle comes out 7 clicks and the handbrake is on.
If the handbrake cables are rusted they may simply lose strands and unwind in a shower of rusty strands of wire when you pull on the handbrake, instead of putting tension on the brake shoes.
It is also possible the brake shoes are glazed and need some sand paper treatment to roughen their surface.
Ancient vehicles and vessels
SGKent is offline
PostPosted: Thu Jul 02, 2015 1:16 pm    Post subject: Reply with quote
1977 lacks this clip that holds the spring to the bar. The ones available for other years do not fit.
George Carlin:
kreemoweet
kreemoweet is offline
PostPosted: Thu Jul 02, 2015 2:10 pm    Post subject: Reply with quote
oscarsnapkin wrote:
. . . adjusted cable tension, but still absolutely no parking brake whatsoever.
An essential part of the parking brake cable tension procedure is ensuring that the parking brake works to spec. So no, the cable tension has NOT been adjusted.
On a side note, the brake assembly shown in the photo posted seems to have Vanagon brake shoes, without the auto-adjuster stuff. Such shoes were (and perhaps are)
being sold mistakenly as late bay brake shoes by many vendors.
'67 bug: seized by the authorities
timvw7476
timvw7476 is offline
PostPosted: Thu Jul 02, 2015 4:52 pm    Post subject: Emergency brake /rear brake adjustment help Reply with quote
If you have fresh cables, I would think you aren't adjusting the stars
tight enough, I like to leave the wheel/tire on, get under and snug the
stars up til I can just get the tire to move, dragging on the drum a bit,
then two clicks per star & check the wheel spins "freely", lower the bus to
the ground and mess with the other ends of the cables, tighten them
til the handle grabs good at 5 clicks out. It settles at 6-7 clicks within days.
