gintaras Samba Member
Joined: November 19, 2012 Posts: 523 Location: Louisville
Posted: Mon Aug 03, 2015 1:51 pm Post subject: Here's a weird one, can someone help? Replaced hoseNo start. |
I was trying to find vacuum leaks, and I removed the clear/translucent hose that leads to the brake booster, the cloudy looking one in the picture.
The engine immediately dies, so we're good there..
But now the engine won't start. No other hoses or wires were removed, just this one, I did double check all of them to make sure I didn't inadvertently pull one off, but no, everything looks good.
Is this some sort of brake safety feature and I need to reset something? _________________ 1979 Deluxe Westy in Mexico Beige |
SGKent  Samba Member
Joined: October 30, 2007 Posts: 42986 Location: at the beach in Northern Wokistan
Posted: Mon Aug 03, 2015 2:06 pm Post subject: |
did you put all 3 ends back into the tee? _________________
Canned Water - the new California approved parts cleaner (except in a drought in which case rub it with sand).
George Carlin:
Skills@EuroCarsPlus:
"never time to do it right but always time to do it twice"
1971 deluxe (sold)
1977 deluxe |
Posted: Mon Aug 03, 2015 2:08 pm Post subject: |
| SGKent wrote: |
| did you put all 3 ends back into the tee? |
yes, and triple checked _________________ 1979 Deluxe Westy in Mexico Beige |
SGKent  Samba Member
Posted: Mon Aug 03, 2015 2:20 pm Post subject: |
were there any backfires when it died _________________
George Carlin:
1971 deluxe (sold)
1977 deluxe |
SGKent  Samba Member
Posted: Mon Aug 03, 2015 2:22 pm Post subject: |
Other possibilities.
1) It is so lean now it doesn't want to run. The CSV won't come back on line until it cools back down.
2) Sometimes other wires get disconnected too - or the key gets left on and burns up a pertronix if you have one. _________________
George Carlin:
1971 deluxe (sold)
1977 deluxe |
Posted: Mon Aug 03, 2015 2:58 pm Post subject: |
It was only running for a few minutes when I pulled off the hose, so it wasn't hot.
I have a California-specific electronic distributor, I'l rule out burning it up trying to start it.
I have been through this engine top to bottom, I'm fairly familiar with where everything goes, and everything looks like it is where it belongs.
I just got back inside after wrapping all the joints in that are with electrical tape, there are zero vacuum leaks on that "circuit" now, but she still won;t start, no backfires.
I do smell gas after I lay on the key for a good 15-20 seconds, so maybe it is flooded? It's almost like it is getting no spark, I guess my next step is to pull a plug and check for spark.. all of this started just by pulling that hose.  _________________ 1979 Deluxe Westy in Mexico Beige |
Randy in Maine Samba Member
Posted: Mon Aug 03, 2015 3:30 pm Post subject: |
Is that "breather hose" connected to the S boot? It should be.
Posted: Mon Aug 03, 2015 6:56 pm Post subject: |
Not my picture.
This is really driving me crazy. I pulled a spark plug wire and I do have a healthy spark.
I smell gas after I crank it for a while, so I have fuel and spark, but why no fire? _________________ 1979 Deluxe Westy in Mexico Beige |
Posted: Mon Aug 03, 2015 7:17 pm Post subject: |
| Pull the plug off the CSV, if the TTS is telling the CSV to fire and the heads have gotten warm enough it will flood and not start. Check for spark by placing the distributor end of the coil wire 1/4" from a ground and seeing if the spark jumps that gap when you crank the engine. |
SGKent  Samba Member
Posted: Mon Aug 03, 2015 9:14 pm Post subject: |
if it is flooded hold the throttle wide open and crank it for about 6 or 7 seconds and let it sit for a minute then try it again. If you smell gasoline it may be flooded as others suggest. _________________
George Carlin:
1971 deluxe (sold)
1977 deluxe |
Posted: Tue Aug 04, 2015 5:05 pm Post subject: |
| SGKent wrote: |
| if it is flooded hold the throttle wide open and crank it for about 6 or 7 seconds and let it sit for a minute then try it again. If you smell gasoline it may be flooded as others suggest. |
This actually did the trick..
Crazy how removing a hose will flood the engine and strand you.
Thanks for the help! _________________ 1979 Deluxe Westy in Mexico Beige |
Posted: Tue Aug 04, 2015 8:43 pm Post subject: |
| gintaras wrote: |
| It was only running for a few minutes when I pulled off the hose, so it wasn't hot. |
This was likely your problem, you ran the engine for just a short while which allowed the heads to get warm enough they didn't need enrichment, but the block had built up almost no heat so the TTS sensor was still telling the CSV then engine was cold and to pour on the fuel flooding the engine. I have seen this problem many times over the years, just a flaw in the way L-jet works on an aircooled engine. |
