PO Stupidity
Gary Haberman
Gary Haberman is offline
PostPosted: Thu Aug 06, 2015 10:10 am    Post subject: PO Stupidity Reply with quote
I just don't understand it-I'm working on my '66 T1-the PO attached the emergency brake lever to the cable using a wire tie (commonly known in the telecommunications world as a tyrap). I needed to replace my rear drums because I bought the car with one wheel lug broken off on the right side. I used the torque meister tool to remove the axle nut (came off with only a little effort) and thought I'd have to use a wheel puller to remove the drum (bought a nice used one on eBay) but the drum came right off-only to find the tyrap connected emergency brake (explains why I had difficulty adjusting the emergency brake on the right side)-in addition, the leaf spring was missing (shouldn't be surprised-they were missing from the front backing plates also). I think this shows the difference between early owners who just want the car to take them where they want to go and as cheaply as possible and "Samba" people to generally want to restore their cars to at least a safe condition. The more I delve into this car, the more I find-works out well-I'm retired and have the time and the desire to learn. Lucky me!
'62 T1 rag top.
I repair radios and dispense free advice on their repair.
60ragtop
Bonneville Belt Bitch
60ragtop is offline
PostPosted: Thu Aug 06, 2015 10:30 am    Post subject: Reply with quote
http://www.thesamba.com/vw/forum/viewtopic.php?t=197964&highlight=pos
Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote:
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote:
maybe he just snapped cause his car sucked Wink
Danwvw
Danwvw is offline
PostPosted: Thu Aug 06, 2015 11:19 am    Post subject: Reply with quote
That's Intresting! Did it work?
1960 Beetle And 1679cc DP W-100 & Dual Zeniths!
Cusser
Cusser is offline
PostPosted: Thu Aug 06, 2015 12:05 pm    Post subject: Re: PO Stupidity Reply with quote
Gary Haberman wrote:
Gary - funny and sad about the parking brake hookup, we've never "seen it all" !!!
By the way: the stronger spring should be on the side with the wheel cylinder (the top) and not the adjuster (bottom).
Tim Donahoe
Tim Donahoe is offline
PostPosted: Thu Aug 06, 2015 1:21 pm    Post subject: Reply with quote
Maybe the PO should have applied some spit to the tie, first. That usually helps.
At least he didn't use a rubber band Rolling Eyes .
Tim
Let's do the Time Warp again!
Richard O'Brien
gt1953
gt1953 is offline
PostPosted: Thu Aug 06, 2015 3:38 pm    Post subject: Reply with quote
Oh My. The infamous tyrap. Correct term too. Poor usage of the tyrap. Like cusser said flip flop the springs. You want to get rid of the rust soak them in cider vinegar over night, rinse in water and use a soft wire wheel. The over night vinegar works great on nuts bolts washers.
72 type 1
72 Squareback
Gary Haberman
PostPosted: Fri Aug 07, 2015 4:51 am    Post subject: Reply with quote
I'm replacing everything on the rear brakes except the push bar and the emergency brake lever. I'll have the try the tip about the vinegar on the bolts. The leaf spring was missing on the backplates but as I don't have a welder (it's on the list which is growing longer every week...so far my wife hasn't said anything), I bought a used set on eBay which I will clean up and paint. I knew about the springs (I review the "BugMe videos and Muir's book prior to working on anything). This car is just full of screw-ups, short cuts and plain old laziness but that's what makes it interesting. I just love these cars.
'62 T1 rag top.
Cusser
Cusser is offline
PostPosted: Fri Aug 07, 2015 6:57 am    Post subject: Reply with quote
Yep, soaking in vinegar (any type, they're all about 5% acetic acid, why it works, I'm a chemist) or dilute phosphoric acid works real well to remove rust. Be a little patient.
Also, those work real well to remove hard water deposits too. I remember a decade ago my shower one-handle faucet was leaking, and I couldn't remove it to fix; the plumber at work said I'd likely need to cut into the rear wall in the closet to fix this. Well, I put vinegar in a sandwich bag and and used duct tape to soak the fitting on the wall in the vinegar, believe I used a piece of wood to support the weight of the bag, and a few hours later was able to unscrew it and fix it, leaving the closet wall intact !!!
VOLKSWAGNUT
Fastest VW Belt Changer
Location: Flippin' a Belt........ .... Off-n-On ... NC USA
VOLKSWAGNUT is offline
PostPosted: Fri Aug 07, 2015 7:45 am    Post subject: Reply with quote
http://www.thesamba.com/vw/forum/viewtopic.php?t=164808
aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited
PostPosted: Fri Aug 07, 2015 8:12 am    Post subject: Reply with quote
Please use this dedicated thread
This topic is locked: you cannot edit posts or make replies.    Forum Index -> Beetle - 1958-1967 All times are Mountain Standard Time/Pacific Daylight Savings Time
