cutter57 Samba Member
Joined: July 26, 2004 Posts: 403 Location: SW Washington
Posted: Fri Oct 02, 2015 4:56 pm Post subject: weird reverse light problem |
My bus is a 1975 Riviera camper. No reverse lights when I bought it. I replaced the tail light assemblies (for other reasons) and paid a little more for the Hella brand. It still was hard to get the bulbs to go into their sockets as they were very, very tight. To get the reverse lights working, I replaced the switch on the tranny nosecone (one prong was missing), and I had to find the wires to it as they had been cut short and capped off. Found them and wired everything together. Even cleaned connections at the splice (to go to both lights) just outside my left tail light. When I go into reverse, my right reverse light comes on immediately, but there is a few seconds delay before the left one comes on. Any ideas why, or what I should do to diagnose and correct this? Any help is appreciated. _________________ the enemy of good is better. |
Wasted youth Samba Member
Joined: July 06, 2012 Posts: 5175 Location: California's Hot and Smoggy Central Valley
Posted: Fri Oct 02, 2015 5:13 pm Post subject: Re: weird reverse light problem |
| cutter57 wrote: |
| My bus is a 1975 Riviera camper. No reverse lights when I bought it. I replaced the tail light assemblies (for other reasons) and paid a little more for the Hella brand. It still was hard to get the bulbs to go into their sockets as they were very, very tight. To get the reverse lights working, I replaced the switch on the tranny nosecone (one prong was missing), and I had to find the wires to it as they had been cut short and capped off. Found them and wired everything together. Even cleaned connections at the splice (to go to both lights) just outside my left tail light. When I go into reverse, my right reverse light comes on immediately, but there is a few seconds delay before the left one comes on. Any ideas why, or what I should do to diagnose and correct this? Any help is appreciated. |
Use test leads to temporarily reverse the order in which the hot lead goes to L and R back up lights. See if problem now changes to the other side.
Verify you have a good ground on the side that is slow. Use a test lead with all wiring removed from that lamp. Test it independently with 12VDC, see if it is still slow.
Verify you have a good ground on the slow lamp housing.
Ring out each leg of wiring to the hot side with an ohmmeter, compare resistance.
Test your back up light switch with a test light and leads. |
Tcash Samba Member
Joined: July 20, 2011 Posts: 12843 Location: San Jose, California, USA
Posted: Fri Oct 02, 2015 5:22 pm Post subject: |
| Use 1156 bulbs. Clean all the grounds. |
Posted: Fri Oct 02, 2015 5:48 pm Post subject: |
thanks wasted youth and Tcash.
If I recall correctly, the bulbs in the tail light assemblies are grounded by their sockets, and there is a ground wire from the assembly's backing plate to the bus. I remember cleaning my wire with sandpaper before attaching it to the backing plate, but I do not recall tracing it to the other end and cleaning that. My assemblies are only 1-2 months old, so I hope nothing is corroded yet. I will check all grounds Monday when I am home from work again.
I like the idea of reversing the wires to see if the problem switches sides.
I think I already have new 1156 bulbs in the assemblies, but I will double check.
I know the problem seems a little trivial, but I want to be sure it does not become a bigger problem.
Thanks for the help. I will post again once I have done some of the steps advised. _________________ the enemy of good is better. |
Posted: Fri Oct 02, 2015 11:20 pm Post subject: |
| cutter57 wrote: |
| I know the problem seems a little trivial, but I want to be sure it does not become a bigger problem. |
Yes. Do consider this may only a symptom of a larger or perhaps different problem. |
Abscate Samba Member
Joined: October 05, 2014 Posts: 24455 Location: NYC/Upstate/ROW
Posted: Sat Oct 03, 2015 4:07 am Post subject: |
| cutter57 wrote: |
Thanks for the help. I will post again once I have done some of the steps advised. |
Double check the bulbs to make sure you have the right ones. A little bit of capacitance difference will make a classic , freshman EE RC circuit which will cause a slight delay in one side coming on.
It's probably not a big problem. _________________ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ π π π |
Posted: Sat Oct 03, 2015 12:40 pm Post subject: |
I think I found my problem. I am at work, but I had a few minutes so I went out to the bus and removed the tail light lens. I have the correct bulb in place (1156), but the socket that houses it has come loose from the metal plate that all three bulbs plug into. I think it is probably a contact issue. Seems like a good place to start. When I get home tomorrow, I will pull the tail light assembly and fix this issue and see if my problem is resolved. I will post my findings here. Thanks to all who have helped. _________________ the enemy of good is better. |
Posted: Mon Oct 05, 2015 9:23 am Post subject: |
Problem fixed. It was just a loose bulb socket in my tail light assembly. Thanks to all who helped. _________________ the enemy of good is better. |
