Ball joints too tight
ctstinnette
ctstinnette is offline
PostPosted: Mon Dec 21, 2015 6:23 pm    Post subject: Ball joints too tight Reply with quote
I've recently completed installing a 2" narrowed adjustable beam and dropped spindles. I decided to change the ball joints at the same time. Now that all the work is done and the car lowered at both ends, I'm ready for alignment but the steering is super tight and the steering won't return to center on its own. I consider the car unsafe to drive. I'm hesitant to spend the money on alignment if this is a permanent situation.
Does anyone have any experience with this situation? Do ball joints have a "break in" period?
dlamyle
dlamyle is offline
PostPosted: Mon Dec 21, 2015 7:54 pm    Post subject: Re: Ball joints too tight Reply with quote
Yeah, I had the same problem. Saw posts saying some aftermarket ball joints were too big and when pressed in became too tight and never wore in. Others said to give it some time. I gave it a couple of years of minimal driving and they finally feel better. I'm sure you could expedite that wait time with some spirited miles on some bumpy roads.
1968 Karmann Ghia, Subaru JDM EJ205, Blouch 16gxt-r turbo, 750cc injectors, STI intercooler, Cobb Accessport, Killer B Holy Headers, Perrin inlet, Cooling Mist Methanol kit, 5spd subaru trans reversed R&P (Subarugears) OBX LSD.
wcfvw69
Samba Purist
wcfvw69 is offline
PostPosted: Mon Dec 21, 2015 8:27 pm    Post subject: Re: Ball joints too tight Reply with quote
Have you isolated the tightness to the ball joints? You may consider un-hooking the tie rod on the knuckle with the front end in the air. Then, turn the knuckle through w/your hands. It shouldn't have much if any resistance as you turn the knuckle side to side. If it binds up and is really hard to do this? You need to go to plan b and install different ball joints.
Where did you buy the ball joints and what brand where they?
The Samba member since 2004.
ctstinnette
PostPosted: Tue Dec 22, 2015 6:08 am    Post subject: Re: Ball joints too tight Reply with quote
They are pretty stiff with no tie rod connected. Before I got started, I could turn a wheel sitting on my garage floor by hand with everything put together. I've not put the car back on the floor since then without the tie rods.
These are from Autozone. Looking through other posts, I couldn't find a consensus of what brand to use.
60ragtop
Bonneville Belt Bitch
60ragtop is offline
PostPosted: Tue Dec 22, 2015 6:27 am    Post subject: Re: Ball joints too tight Reply with quote
I made that mistake also by using a "German" brand Embarassed and it was undriveable. I tried lots of remedies to loosen up them up without any luck. I ended up using TRW brand,what a difference in the feel. Time consuming lesson to learn.
Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote:
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote:
maybe he just snapped cause his car sucked Wink
wcfvw69
Samba Purist
wcfvw69 is offline
PostPosted: Tue Dec 22, 2015 7:05 am    Post subject: Re: Ball joints too tight Reply with quote
Sadly, the only cure is to remove these ball joints and take them back to Autozone for a refund. They need to be held accountable for selling these lousy, Chinese parts. I'm not sure what brand bug ball joints are acceptable these days. The poster above says TRW are acceptable.
You may post a question in the late model bug forum asking what are known good ball joints w/out binding. You could also call Cip-1 and ask them what bug ball joints they recommend that are not having binding issues. When I bought my Bay window bus ball joints, I called Cip-1. The salesman was honest and said they'd had some complaint with binding from their "German" brand ball joints. After lots of research, I bought Nakata's and have been happy with them.
When I last installed bug ball joints (I don't remember the brand), before I pressed them in, I put the nut on the stud of the ball joint and turned the stud w/my wrench to get a "feel" for how tight they were. They were all smooth and not much effort was needed to spin the stud in the ball joint. I also mic'd the area of the ball joint to be pressed in compared to what I pulled out.
ghia4mea
ghia4mea is offline
PostPosted: Fri Dec 25, 2015 12:00 pm    Post subject: Re: Ball joints too tight Reply with quote
Sadly I had the exact problem. I gave them over a year to loosen up but they never did. When the car was on jack stands there was no way to turn the wheels by gripping the tires. It was terrible.
My friend drilled and tapped the ball joints and installed zerk fittings which allowed grease to be injected. Once greased they were smooth as silk and everything was back to normal.
I have no idea what my friend did to drill and tap them, but I do know he is an old time very patient mechanic. He is a treasure.
nextgen
nextgen is offline
PostPosted: Wed Dec 30, 2015 2:53 pm    Post subject: Re: Ball joints too tight Reply with quote
Talk about a dummy, I used dropped front spindles and was told to go for the special ball joints for lowered cars-- first of all if you use lowered spindles you do not have to change anything like the shocks or ball joints.
Well it was tight then one day I hit a pot hole and it got hard to turn. One of the lower ball joints had a piece of the crown break off. I bought a rebuilt arm with the ball joint installed, Simple replacement. The car was drive able so no big deal. But no high speed driving
NOT from China Car is away for the winter, will fix it next spring
email: [email protected]
The TYPE IV UPRIGHT CONVERSION MANUAL
BEETLE MAGNETIC DEFLECTOR SHIELDS
LETS TALK DUBS https://www.youtube.com/results?search_query=joe+cali+ghia https://letstalkdubs.libsyn.com/ep-200-joe-cali-ty...qI3xJTCzjs
runamoc Premium Member
runamoc is offline
PostPosted: Sat Jan 02, 2016 9:41 am    Post subject: Re: Ball joints too tight Reply with quote
Not implying anything..but..ball joints that aren't lined up with the 'notches' are hard to turn. Cool
60ragtop
60ragtop is offline
PostPosted: Sat Jan 02, 2016 11:55 am    Post subject: Re: Ball joints too tight Reply with quote
lining up the notches has nothing to do with poor fitting ball joints Wink
The notches are for the proper arc movement going thru the suspension travel.
Rick
runamoc is offline
PostPosted: Sat Jan 02, 2016 3:54 pm    Post subject: Re: Ball joints too tight Reply with quote
I re-read the OP and I didn't see anything about poor fitting ball joints Wink Only that they mentioned the car had a tight steering problem and suspected the ball joints because they had been recently replaced. I 'acquired' a ACVW that had the ball joints installed in such a way the 'notches' didn't line up. It was hard to turn the steering. Jacked-up, with the suspension all the way down, it was really hard to turn the steering wheel. So yes, that could be something to check because I have experienced such a symptom in the past and that was the problem. Here, I have some pix of the PO 'craftsmanship'. Laughing
CapnMark
CapnMark is offline
PostPosted: Fri May 27, 2016 11:17 am    Post subject: Re: Ball joints too tight Reply with quote
I have had similar problems with my '71 Ghia and the Meyle balljoints that I installed. I thought that they may have freed themselves up, but after three years I have finally had enough and am going to replace them because they are spoiling the enjoyment of my Ghia.
I have the following choices:
Euromax (Inexpensive)
Bilstein / Febi (Inexpensive)
OCap (Inexpensive)
Dansk (Inexpensive)
Belkarnly (Not cheap)
TRW (Highest price)
Although I have a "toy" budget and would prefer to keep the price sensible, I understand that quality normally comes at a price and as a general rule you get what you pay for. Does anyone have any experience with the above brands, good or bad please?
Thank you!
60ragtop
60ragtop is offline
PostPosted: Fri May 27, 2016 5:52 pm    Post subject: Re: Ball joints too tight Reply with quote
I used TRW after my mistake with buying MEYLE brand.
money well spent if you want them right.
Rick
wcfvw69
Samba Purist
wcfvw69 is offline
PostPosted: Fri May 27, 2016 9:22 pm    Post subject: Re: Ball joints too tight Reply with quote
X2 on TRW.
When I did the ball joints on my bus, I called Cip-1 and asked what brand their "genuine" German made joints where. I don't recall which brand but it was a name we all recognized. He also was honest and said he's heard feedback about them being tight. He said the cheaper Euromax brand where getting good feedback though. I ended up with Nakata ball joints after doing a lot of research. They were fine.
For the amount of work it is to install the ball joints, I'd go with the best quality and brand (TRW) you can get. I'd also bench check them before installation. Basically, take them out of the box. With the nut on the ball joint stud, put a wrench on the nut and turn the stud in the ball joint. It shouldn't take too much effort to spin the stud. Some people have reported that it took a strong effort to spin the stud in the ball joint. They still went ahead and installed them and found they were too tight and caused the problems you're having.
John Moxon Premium Member
John Moxon is offline
PostPosted: Sat May 28, 2016 12:22 am    Post subject: Re: Ball joints too tight Reply with quote
Added to the "How To" stickies under the "Running Gear Maintenance" section.
Thanks for your input everyone. Smile
John.
CapnMark
CapnMark is offline
PostPosted: Sat May 28, 2016 8:19 am    Post subject: Re: Ball joints too tight Reply with quote
Thank you for the advice. TRW it is then - I'll break out the credit card. Smile
bobnorman
Samba Newfoundlander
bobnorman is offline
PostPosted: Sun May 29, 2016 8:04 pm    Post subject: Re: Ball joints too tight Reply with quote
X2 on TRW.
When I did the ball joints on my bus, I called Cip-1 and asked what brand their "genuine" German made joints where. I don't recall which brand but it was a name we all recognized. He also was honest and said he's heard feedback about them being tight. He said the cheaper Euromax brand where getting good feedback though...
Yeah... Euromax. Those were the one with the lip that folded like a cheese slice when I tied to install them.
If a product has Euro in the name chances are they're trying to make you think European when in fact they are not, in this case Made in China... My experience here, just past half way down the page...
http://www.thesamba.com/vw/forum/viewtopic.php?t=4...p;start=20
I ended up getting the NAPA Altrom brand, made by SIDEM. Made in the EU (Belgium I believe) they're shorter than original, but seemed to go in ok and don't seem to bind... car is not on the road yet so time will tell.
Air does not freeze. Air does not boil.
http://www.thesamba.com/vw/forum/viewtopic.php?t=289807
wcfvw69
Samba Purist
wcfvw69 is offline
PostPosted: Sun May 29, 2016 8:44 pm    Post subject: Re: Ball joints too tight Reply with quote
bobnorman wrote:
X2 on TRW.
You have to love poorly made China products. Figures they were garbage yet the "salesmen" at CIP-1 said they were getting good feedback..
I also agree with you in that I wouldn't buy anything "Euromax" branded. That brand is at the same level as EMPI.
J1
J1 is offline
PostPosted: Thu Jun 01, 2017 8:16 pm    Post subject: Re: Ball joints too tight Reply with quote
My just bought new lower TRW ball joints are too tight. Won't budge unless it's in a vise and you really really crank on them. With the above bench test the stud does not spin. Based on this thread might I have some lemons? Seems like TRW is usually ok so maybe I will ask the retailer to let me look through his stock for better ones.
Uppers seem fine. Firm but movable by hand.
1971 Ghia coupe. Assume I know nothing and you'll be pretty darn close to the truth.
Bleyseng
Bleyseng is offline
PostPosted: Thu Jun 01, 2017 8:45 pm    Post subject: Re: Ball joints too tight Reply with quote
Hmmm, I installed the German brand balljoints and they are fine. They were tight for a day of driving.
I spent $1200 getting it aligned along with new rear bushings/ Torsion bar adjustment.
Drives sweet now like new.
70 Ghia Black convert-9/69 build date-stock w/133k 1600 SP-barn find now with a rebuilt tranny and engine
77 Westy 2.0L w/Ljet, Camper Special engine-95hp and with LSD!(sold)
76 Porsche 914 2.1L L20c, 120hp Djet (sold)
87 Syncro Westy Titan Red 2.1L 2 knob 100k miles
