50Splitman Samba Member
Posted: Fri Mar 18, 2016 6:44 am Post subject: 25hp air deflector tins? |
Is anyone putting these tins http://www.thesamba.com/vw/classifieds/detail.php?id=1881775 back in place after a rebuild? I have the small square bottom deflectors installed that go under the cylinders, but I wasn't sure if these will really make a difference on what essentially will be a car that maybe gets a 100-150 miles a year driving when it is done  |
splitjunkie Samba Member
Posted: Fri Mar 18, 2016 11:07 am Post subject: Re: 25hp air deflector tins? |
VW did away with that style of deflector for a reason.
I would run the later ones since it will make the engine more reliable and only a really anal detail freak would climb under the car to look for them. _________________ Chris
pastellgreen Samba Member
Joined: January 06, 2012 Posts: 1255 Location: Germany
Posted: Fri Mar 18, 2016 11:13 am Post subject: Re: 25hp air deflector tins? |
Price is too high for that nearly nobody would use them....
the 36hp engine has more power, more compression, the same distance from cylinders and would get hotter than the 25hp engine, but at that era, VW left them away.
The deflectors would not let the air between the cylinders? |
Posted: Fri Mar 18, 2016 3:35 pm Post subject: Re: 25hp air deflector tins? |
The top deflectors in the ad were the old style deflectors. They were replaced by the square sheet metal with the tabs that clip onto the bottom cylinder studs.
You should never install both. The square one that mounts on the bottom provide superior cooling. _________________ Chris
Posted: Fri Mar 18, 2016 4:10 pm Post subject: Re: 25hp air deflector tins? |
| Thanks everyone for the feedback, this really helped! I will stick with only using the small square air deflector tins that are already installed on my rebuilt engine clipped under the cylinders (thanks, Joe R.!). |
Posted: Sun Mar 20, 2016 12:13 am Post subject: Re: 25hp air deflector tins? |
| By the way, my stock industrial engine from 1953, 25hp, had both installed... |
