Lilchas57 Samba Member
Posted: Sun Jul 24, 2016 8:21 am Post subject: Special drums |
| Doing a dune buggy project and working on rear brakes, The special rear 5 - lug drums have no access hole toward the outer edge to adjust the brake shoes. Do I have to add hole to adjust and if so why didn't they think of it, thanks |
jsturtlebuggy Samba Member
Joined: August 24, 2005 Posts: 4627 Location: Fair Oaks/Orangevale, CA
Posted: Sun Jul 24, 2016 3:41 pm Post subject: Re: Special drums |
With no picture, no one is going to see how special those rear drums are.
Every wide 5 drum I seen has a hole for adjusting the brakes.
You could drill holes in the backing plates like what is done on VWs using 4lug drums. _________________ Joseph
Elrod Motorsports
Motion Tire Motorsports
Into Volkswagens since 1960 |
Donald Mace Samba Member
Joined: September 26, 2011 Posts: 39 Location: NOR CAL
Posted: Mon Jul 25, 2016 1:36 pm Post subject: Re: Special drums |
| They could be CB perf drums, seems like they had no holes on the face |
Posted: Mon Jul 25, 2016 6:06 pm Post subject: Re: Special drums |
Ok, my curiosity is wanting to know more about 5lug drums with no adjusting hole in the face.
Could the OP be talking about some other bolt pattern then the wide 5 205mm bolt pattern?
Not knowing what year the buggy is or the parts being used, or a picture of such can lead to all kinds of speculation. _________________ Joseph
Elrod Motorsports
Posted: Fri Jul 29, 2016 12:42 pm Post subject: Re: Special drums |
| Joe as you know anything is possible. Yea redrilled 4 lug drums. |
Posted: Sat Jul 30, 2016 4:50 am Post subject: Re: Special drums |
| Yes the drums have no hole in front , but after looking behind the brake backing plate, through all the dirt and gunk I found two holes in which to adjust brakes, sorry |
