dave1 Samba Member
Joined: September 12, 2003 Posts: 531 Location: United Kingdom, London
Posted: Fri Sep 02, 2016 1:20 pm Post subject: 52 Split heater & choke locations |
Hi
just looking at my floor pan. It looks like the choke cable location has been blanked off & wanted to check that the heater pipe protruding from the floor pan tunnel is correct. I'll attach a few pictures. Is it possible for someone attach exact pictures for both locations & can I purchase the choke section?
thank you Dave
dave1 Samba Member
Posted: Thu Sep 08, 2016 12:57 am Post subject: Re: 52 Split heater & choke locations |
Hi guys
Could someone post a picture of the choke cable & heater cable area. My car is a early 52
Thank you Dave |
dave1 Samba Member
Posted: Fri Sep 23, 2016 3:27 pm Post subject: Re: 52 Split heater & choke locations |
Hi Guys
Any help appreciated thanks |
Grant Reiling Samba Slow-Change Artist
Joined: November 28, 2003 Posts: 494 Location: behind the wheel
Posted: Fri Sep 23, 2016 4:10 pm Post subject: Re: 52 Split heater & choke locations |
dave1 wrote: |
Hi Guys
OK Dave1, Trying this again; as mentioned before, not the world's best photography, but what was obtainable inside the garage.
I posted them before when your post appeared; though given null response figured nobody cared. Not the most original example, or even correct (older) restoration...though a numbers-matching, VW documented vehicle; thus the concern you face WRT locations of parts will be accurate to the purpose. I truly hope -this helps.
See here (heat control):
and: (choke control)
Grant |
Porsche904 Samba Member
Posted: Sat Sep 24, 2016 12:16 pm Post subject: Re: 52 Split heater & choke locations |
Dave, pm me as I can't upload pics I have 2 pans in stock and can take exact meassurements, no problem |
Posted: Sat Sep 24, 2016 1:38 pm Post subject: Re: 52 Split heater & choke locations |
Porsche904 wrote: |
You're welcome; time for somebody else to step up.  |
dave1 Samba Member
Posted: Sun Sep 25, 2016 2:00 pm Post subject: Re: 52 Split heater & choke locations |
Thank you Porsche904 & Grant for the excellent details & pictures. I can now move forward
best regards
Dave |
type4split Samba Member
Joined: May 23, 2007 Posts: 728 Location: Hamilton, Indiana
Posted: Mon Aug 12, 2024 7:22 pm Post subject: Re: 52 Split heater & choke locations |
I have a similar (exact) issue. The choke am able picture isn’t valid any more. Can someone please post a picture?
Also the choke exits out of back of pan if I’m not mistaken? _________________ '67 deluxe bus w/the little windows
'52 beetle
'55 convertible
'50-something convertible (*need ribbed 'vert quarter panel )
'63 "milo" beetle
Part, parts and more parts |
MLockwood Samba Member
Posted: Thu Aug 15, 2024 1:08 pm Post subject: Re: 52 Split heater & choke locations |
Hope these help....Mark
Posted: Thu Aug 15, 2024 2:41 pm Post subject: Re: 52 Split heater & choke locations |
Hi mark. Thanks for additional photos. Your choke is looking a little modified?!? What up with that 1/4-20 looking bolt thread? Is that the stem without the plastic handle?
Here is mine. Seems to be cut at the tunnel?
'52 beetle
'55 convertible
'63 "milo" beetle
Posted: Fri Aug 16, 2024 9:28 am Post subject: Re: 52 Split heater & choke locations |
Yes, that's the way it was when I got the car. I have the correct L handle and cable for it. |
