kennethdlt Samba Member
Joined: April 17, 2015 Posts: 12 Location: Santa Rosa Ca
Posted: Fri Sep 02, 2016 8:36 pm Post subject: Oil Cooling. External oil Coolers and how-to's |
| Hey guys I haven't had much success looking for a thread on external oil coolers. I would love to have any advice or build threads on what anyone has done to keep an extra edge on a big hot engine. What external oil coolers are recommended for a 71 Ghia. I have a 1914cc with dual 40s and it's making lots of heat. Thanks! |
Tbirdusa Samba Member
Joined: November 29, 2006 Posts: 1460 Location: Kansas City, MO
Posted: Fri Sep 02, 2016 8:46 pm Post subject: Re: Oil Cooling. External oil Coolers and how-to's |
I run a Setrab from Jon at air cooled.net and have been pleased. Compact, quiet and a nice piece. Should also run a thermostatically controlled sandwich adapter at the oil filter. It diverts colder oil away from the cooler until needed ( 180 degrees)
You are full flowed, yes? _________________ Royals 2015 World Champions
Chiefs 2017 Superbowl winner
1986 Falco records Rock Me Amadeus! |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15602 Location: Deep in the 405
Posted: Fri Sep 02, 2016 8:47 pm Post subject: Re: Oil Cooling. External oil Coolers and how-to's |
You need to address what is causing the heat and not just patch it with a Band-Aid (oil cooler). I'll guess 80% of the people that put them on their cars do not need them. Tell us more about your engine. What oil are you using? How hot is the oil getting and how hot do you think it should be?
I run a 2276 in my Ghia and I do not have an auxillary oil cooler. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Posted: Fri Sep 02, 2016 9:40 pm Post subject: Re: Oil Cooling. External oil Coolers and how-to's |
I agree with Dave. Mine doesn't need it and it's a 2332 mild compression by today's hot street standards. If you do put the aux cooler on, get the thermo plate diverter though. My engine struggled to warm up with just the setrab in the loop as it would pull heat away I was trying to build on warm up cycle.
I got it, glad I did. Needed? Probably not. _________________ Royals 2015 World Champions
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20888 Location: Just a tiny bit west of Yosemite Valley
Posted: Sat Sep 03, 2016 7:21 am Post subject: Re: Oil Cooling. External oil Coolers and how-to's |
Interesting comment on need.... Summers here runs anywhere from 95° to 105° daily, and last few time out motor has been HOT, heat radiating off it is terrific after shut down... Guess first thing would be to get good temperature measurement of oil.... Had not thought about adding a cooler until mentioned now...
Dale _________________ “Fear The Government That Wants To Take Your Guns"
mark tucker Samba Member
Joined: April 08, 2009 Posts: 23945 Location: SHALIMAR ,FLORIDA
Posted: Sat Sep 03, 2016 7:42 am Post subject: Re: Oil Cooling. External oil Coolers and how-to's |
| fix cooling issues. add cooler if needed. I gots one but dont realy need it. but nice to have on those 105+days. |
Cusser Samba Member
Joined: October 02, 2006 Posts: 33386 Location: Hot Arizona
Posted: Sat Sep 03, 2016 7:58 am Post subject: Re: Oil Cooling. External oil Coolers and how-to's |
In 1976 I built up a 1600cc SP engine into an 1835cc DP engine. I didn't have doghouse cooler, this was going into my 1970 sedan, and I had dealer-installed AC, and Arizona heat to deal with. Doghouse stuff was expensive then, and I wanted to add an oil filter to this engine, and read in Hot VWs magazine about fan shroud mounted external oil cooler to get the stock oil cooler out of the fan shroud (I was really cooking #3 and #4, could tell by how fast the spark plug seals hardened).
So I still have this set-up, still on my 1835cc engine. Note that this arrangement is frowned upon by many on The Samba, so I'm not pushing for it, just relaying what has worked for me. However, in ensuing years I removed the oil filter part and went to a Maxi2 pump/filter, to free up more room in engine compartment and not have to use aluminum foil "dams" to prevent oil leakage during filter changes. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
esde Samba Member
Joined: October 20, 2007 Posts: 6381 Location: central rust belt
Posted: Sat Sep 03, 2016 8:09 am Post subject: Re: Oil Cooling. External oil Coolers and how-to's |
A small Mocal cooler and fan on my 2161 made the difference between (borderline) too hot on a 95º day and fine. I had all the tin, good tune, good air supply, stock doghouse, but on a 95º day temps would hit 225-230 and I couldn't live with that. The cooler is small (6"x10") and the fan only runs on a hard pull, or extended sitting in traffic. No more worry _________________ modok wrote:
