Scat C25 cam
johnanddes
Satellite Wrangler
johnanddes is offline
PostPosted: Fri Sep 02, 2016 9:20 pm    Post subject: Scat C25 cam Reply with quote
So precisely I posted that I am going with a 1679. Today, I decided to go a different direction. I called the short block builder and decided on a scat c25 cam with stock crank, 1600 Mahler pistons and rebuilt sp stock heads. The question is this:
Can I run a scat C25 cam with all other components (to include 30 pict-3 and screamer 019 electronic points dist) and have a good motor? I have a set of rocker shafts with swivel balls in the rocker arms that I was going to run. I should mention that the case is a AS41 Brazilian case, crank, rods. Thanks for the feedback.
(Edited to mention the Brazilian stuff)
John
1969 documented numbers matching bug
1968 F250
Keepin the ISS from colliding with space junk
LeninCas
LeninCas is offline
PostPosted: Sat Sep 03, 2016 12:36 am    Post subject: Re: Scat C25 cam Reply with quote
I'd use a SVDA but that's just me.
one, two, many
one too many
Alstrup
Alstrup is offline
PostPosted: Sat Sep 03, 2016 3:02 am    Post subject: Re: Scat C25 cam Reply with quote
X2
gt1953
gt1953 is offline
PostPosted: Sat Sep 03, 2016 7:58 am    Post subject: Re: Scat C25 cam Reply with quote
Looks like a nice easy set up. If you feel the need to part with the or swap out and even trade me the 019 for one of my SVDA's let me know.
72 type 1
72 Squareback
