Chrissteve22 Samba Member
Posted: Mon Nov 28, 2016 3:26 pm Post subject: 1972 super beetle tough time starting up/ takes long to get warm |
So I've been having this problem for a little while now and can't seem to fix it. Whenever I start my bug, it will start very slow and have a tough time getting warm and staying on so it will just stall out either right away or after a minute or 2. This gets worse when it is cold which is understandable but it will also happen when it is pretty warm too. I changed both fuel filters, a tune up is done, we adjusted the carb so it will run a little richer to try and get hot quicker but it doesn't help much at all. I am wondering if putting a thinner oil in would make a little difference like 5w-30. I'm running 10w-30 right now. But, I just can't figure out what the problem may be to get it running and stay idling when I first turn the car on. When the car is hot, it runs fine, but the problem is getting to that point. |
hotsam Samba Member
Joined: December 02, 2015 Posts: 368 Location: Ashburn, VA
Posted: Mon Nov 28, 2016 4:02 pm Post subject: Re: 1972 super beetle tough time starting up/ takes long to get warm |
Check and see if you have a thermostat installed. _________________ 1968 Beetle |
Posted: Mon Nov 28, 2016 4:04 pm Post subject: Re: 1972 super beetle tough time starting up/ takes long to get warm |
Where would that be located if I have one? |
hotsam Samba Member
Posted: Mon Nov 28, 2016 5:48 pm Post subject: Re: 1972 super beetle tough time starting up/ takes long to get warm |
Chrissteve22 wrote: |
Underneath, passenger's side.
hitest Samba Member
Joined: September 30, 2008 Posts: 10325 Location: Prime Meridian, ID
Posted: Mon Nov 28, 2016 8:24 pm Post subject: Re: 1972 super beetle tough time starting up/ takes long to get warm |
We can't make guesses until you tell us what carb you have and whether you have a working choke on it.
This so far gives me Weber Progressive goosebumps... _________________
EverettB wrote: |
FU#5 |
andydlc Samba Member
Posted: Tue Nov 29, 2016 2:55 pm Post subject: Re: 1972 super beetle tough time starting up/ takes long to get warm |
This could be a distributor issue, have you got points in the distributor or have you got an electronic Ignition ? Is your timing correct? |
AngelDeVille Samba Member
Posted: Tue Nov 29, 2016 3:49 pm Post subject: Re: 1972 super beetle tough time starting up/ takes long to get warm |
Running rich/fouled plugs? _________________ Sent via two tin cans connected by a string and a jailbroken Atari 2600...
Suck it up, Buttercup! |
Posted: Tue Nov 29, 2016 5:17 pm Post subject: Re: 1972 super beetle tough time starting up/ takes long to get warm |
begin by posting a picture of your engine. We can often find issues just from that. _________________ It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net |
