How to remove spray on sound deadener or undercoating
Page: 1, 2, 3  Next
rennie
rennie is offline
PostPosted: Mon Apr 24, 2017 6:25 pm    Post subject: How to remove spray on sound deadener or undercoating Reply with quote
I've combed the forums and couldn't find anything specifically addressing removal of old, dried, and crusty SPRAY ON sound deadening (not adhesive mat)... the black, rough surfaced stuff, similar to this pic:
I saw the thread on cleaning an engine: https://www.thesamba.com/vw/forum/viewtopic.php?t=475553, but it doesn't mention removing the nightmare spray on material.
What started as a carb leak fix has lead to re-doing the fuel tank and possibly a freeway flyer... and while in there, why not try to scrape out the engine bay, which currently looks like below (spray on deadener on top of OG paint):
In the forums, these items were mentioned for paint removal: Citrus Strip, Easy Off, purple degreaser, gas on a rag, Simple Green, Lifter-1 Bug/Tar Remover, lacquer thinner, kerosene, etc.
Has anyone used any of these to successfully remove hardened, decades-old, crusty, black spray on sound deadener? …or know of any other affective method?
jason
jason is offline
PostPosted: Mon Apr 24, 2017 9:24 pm    Post subject: Re: How to remove spray on sound deadener / deadening? Reply with quote
I have used undercoater remover from FLAPS with ok success. The spray on paint remover works good also. Get it wet and let it sit, when it dries reapply. Comes right off.
rennie
rennie is offline
PostPosted: Mon Apr 24, 2017 9:59 pm    Post subject: Re: How to remove spray on sound deadener / deadening? Reply with quote
Flap discs are a good thought but two things I should have mentioned are that the entire engine bay needs doing, and I'd like to preserve the OG paint if possible, though I may be dreaming. I think flap discs would destroy the OG paint right away.
Hokie87
Hokie87 is offline
PostPosted: Tue Apr 25, 2017 3:46 pm    Post subject: Re: How to remove spray on sound deadener / deadening? Reply with quote
Eastwood Pre works well, too. It takes some elbow grease and a lot of rags but won't hurt the paint underneath. http://www.eastwood.com/eastwood-pre-painting-prep.html
VWLady
Crazy VW Lady
VWLady is offline
PostPosted: Tue Apr 25, 2017 3:56 pm    Post subject: Re: How to remove spray on sound deadener / deadening? Reply with quote
Warm an area up with a heat gun and use a plastic putty knife to get the big stuff off then one of the chemical products mentioned.
rennie
rennie is offline
PostPosted: Tue Apr 25, 2017 5:55 pm    Post subject: Re: How to remove spray on sound deadener / deadening? Reply with quote
Thanks, will check out Eastwood, and heat is a good idea, too.
Rang two decent body shops today. They said they just use paint remover, but they aren't trying to preserve OG paint underneath.
I'll let you know results when/if I find something that works well.
hitest
hitest is offline
PostPosted: Tue Apr 25, 2017 8:52 pm    Post subject: Re: How to remove spray on sound deadener / deadening? Reply with quote
I could overload the server with pictures of my removal of tar from my '66. ^^^ This method is painstaking- but it was the only way I could do it.
FU#5
rennie
rennie is offline
PostPosted: Fri Apr 28, 2017 4:54 pm    Post subject: Re: How to remove spray on sound deadener or undercoating? Reply with quote
About 3 hrs work (thick in places!). Support pillar is how clean it eventually comes and now serves as motivation to keep going. I'm committed to the long haul...
Bought/using a heat gun and plastic scrapers, which tend to heat up but need to stay cool for efficient scraping (no flexing).
2 sq ft done, 20 to go... I'll be the tortoise on this one, not the hare...
oldbusboy
oldbusboy is offline
PostPosted: Sat Apr 29, 2017 9:39 am    Post subject: Re: How to remove spray on sound deadener or undercoating Reply with quote
I know some guys who have used cans of compressed air, the kind you use for blowing dust off electronic parts. This is for stock VW undercoating. I believe they inverse the can while spraying, or shake the can and by doing so the air that comes out is extremely cold. Once the area you spray becomes brittle you can use a very stiff plastic putty knife to start chipping away.
Worth a shot. The cans of air aren't expensive and there are no fumes unlike heating the tar with a heat gun.
https://www.amazon.ca/Emzone-Air-Duster-284g-10Oz-...ressed+air
Trevor
1958 kombi
1968 porsche
Erik G
Erik G is offline
PostPosted: Sat Apr 29, 2017 1:44 pm    Post subject: Re: How to remove spray on sound deadener / deadening? Reply with quote
LOL, he didn't say flap discs
no he said FLAPS. Friendly Local Auto Parts Store
rennie
rennie is offline
PostPosted: Sat Apr 29, 2017 4:30 pm    Post subject: Re: How to remove spray on sound deadener or undercoating Reply with quote
Trevor
Thanks - ya I've read about doing it cold. I have so much to do that you're right, it's certainly worth a try.
Interestingly, heating the tar-like stuff hasn't been bad - can't even smell it. It just becomes pliable - doesn't melt much at all. But, I'll give cold a try.
Ah, thanks, another acronym under the belt now. Thought he meant the drill flap sanding method...
BarryL Premium Member
BarryL is offline
PostPosted: Sat Apr 29, 2017 6:56 pm    Post subject: Re: How to remove spray on sound deadener or undercoating? Reply with quote
rennie wrote:
...plastic scrapers, which tend to heat up but need to stay cool for efficient scraping (no flexing).
What about something like a laminated bamboo small kitchen spatula or teflon kitchen tool? Or even a wooden stir stick from the hardware paint department that you could sharpen and form yourself?
rennie
rennie is offline
PostPosted: Mon May 01, 2017 9:23 am    Post subject: Re: How to remove spray on sound deadener or undercoating? Reply with quote
I've been cutting down the plastic scrapers and re-sharpening them but wood ones could work better and last longer! Brilliant. Will let you know.
Last night I managed to get the first step of gook off the fuel tray underside and that back corner in general. It's the hardest area to access, so I figured it wise to do first whilst motivated! Now it just needs the "Eastwood PRE" cleaning attack. More pics soon!
rennie
rennie is offline
PostPosted: Sat May 27, 2017 11:24 am    Post subject: Re: How to remove spray on sound deadener or undercoating Reply with quote
Progress pics after about 19 hrs.
Using heat gun with firm plastic scrapers to get the bulk off, then reheating and wiping off excess residue with rags, then using clean rags with off-the-shelf acetone for the final clean up (decided not to by Eastwood PRE after I rang them and they said the California version has a very high acetone content... and I've learned straight acetone is working just fine). No luck with paint remover, and didn't want to risk using oven cleaner with OG paint preservation in mind.
Anything other than plastic or teflon scrapers (ie: bamboo/wood) scratches the nice OG paint hiding underneath. Some areas, like by the battery, have very hardened black deadener that heat doesn't affect. Using a metal 'wood chisel' there at a very careful/light pressure/consistent angle to slowly scrape it off without scratching the OG paint.
Cleaning the calked seams is tricky as the paint wants to come off more easily than paint on metal, but fine and focused light scraping and light rag wipes is working out okay. Sometimes I feel like I'm going at an archaeologist's pace!
I've come across no rusty areas, and still have fingers crossed on that front. My chosen method is slow going but it's coming along, and the hours of later enjoyment will far exceed the hours of work to remove this dreadful stuff.
I've almost got the other side done, too, and this weekend hope to move to the 'roof'...
ronjonlasvegas
ronjonlasvegas is offline
PostPosted: Sat May 27, 2017 11:51 am    Post subject: Re: How to remove spray on sound deadener or undercoating Reply with quote
Nice job. Keep at it. The area you have finished looks fantastic.
I am in the process of removing four layers of old paint off my DC so I know it is not easy. I also need to remove the spay bomb paint off my interior for all areas that will not be covered with panels. The prior owner used trunk splatter black paint on mine and it is not too bad to remove. I am really glad they did not use sound deadner.
I commend you on your patience and persistence.
rennie
rennie is offline
PostPosted: Sat May 27, 2017 8:35 pm    Post subject: Re: How to remove spray on sound deadener or undercoating Reply with quote
Thanks ronjon. I've seen your thread, which along with others helped inspire me to dive in and do it. Impressive how much you're doing to save your postal yellow!
Left side progress pic below, after about 23 hrs on that side.
Am having to scrape gently yet firmly with the chisel on the flat tray area... while using light heat so as not to soften the paint too much. The tar there has hardened to a crust and nothing penetrates the bulk well enough to scrape it off. Left side is taking more hours than the right.
Pic also shows the aft side wall and how clean it gets when reheating it after the bulk is removed and just using a rag without acetone. Lower on the sidewall, and tray, you can see where the acetone rag was used for final clean up... matching the forward sections. I'll detail out the seam calk and vents more later.
BarryL is offline
PostPosted: Sun May 28, 2017 8:47 am    Post subject: Re: How to remove spray on sound deadener or undercoating Reply with quote
Epic task you are tackling.
In retrospect it seems so ridiculous to have that stuff applied in there. Plus, imagine what the applier person looked like after that job. One good thing is it sure protected the original paint.
rennie
rennie is offline
PostPosted: Sun May 28, 2017 9:57 am    Post subject: Re: How to remove spray on sound deadener or undercoating Reply with quote
I too can't fathom having a nice pearl white engine area and spraying black tar all over it.
But you're right, it has well preserved the paint - it shines up nicely after TR3'ing it. Reminds me of another old car I had from an OG owner that chain smoked - waxy/sticky nicotine(?) had covered all the interior chrome. After hours of polishing, it looked brand new - completely preserved. I suppose there is some thanks for historical madness!
motofly196
motofly196 is offline
PostPosted: Sun May 28, 2017 10:26 pm    Post subject: Re: How to remove spray on sound deadener or undercoating Reply with quote
You're pretty far into this project, but I also had to deal with the same thing on my Single Cab behind the seat and dash. What works great and doesn't harm the original paint....bug and tar remover. It literally MELTS the undercoating! If it's thick in areas, you might need to spray it a few times, but it was melting off as I was spraying on the bug and tar remover. Good stuff!
Malokin Martin
Malokin Martin is offline
PostPosted: Sun May 28, 2017 11:18 pm    Post subject: Re: How to remove spray on sound deadener or undercoating Reply with quote
People have had relatively good success with an air needle sander. Never done it myself though. I think it may pock mark the paint though. One idea.
Page: 1, 2, 3  Next
