DORIGTT Samba Member
Joined: October 01, 2003 Posts: 260 Location: Forest Grove, OR
Posted: Fri Jul 07, 2017 8:22 pm Post subject: How to remove the qtr window lower trim pieces? |
Hey all,
How do these come out?
_________________ To err is human, but if the eraser wears out before the pencil does you're a major screw-up. |
xzener Samba Member
Posted: Sat Jul 08, 2017 10:34 am Post subject: Re: How to remove the qtr window lower trim pieces? |
I believe mine were attached with an ample supply of an RTV like substance. I used a thin spackle tool to cut through it, and ran into 3 screws on the bottom which attach the trim to the sill. I then took a rubber mallet and gently hit it in a forward direction (toward the doors). Eventually, the trim came free. The trim has notches where the little screws go through. After you move the trim forward, the screws eventually have an opening where they can be freed.
Good luck.
_________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
Posted: Sat Jul 08, 2017 6:04 pm Post subject: Re: How to remove the qtr window lower trim pieces? |
Thanks xzener! I'll try it in the morning, or after I get home from date-night. _________________ To err is human, but if the eraser wears out before the pencil does you're a major screw-up. |
berliner Samba Member
Joined: December 27, 2006 Posts: 440 Location: west coast canada
Posted: Sat Jul 08, 2017 6:38 pm Post subject: Re: How to remove the qtr window lower trim pieces? |
Earlier ones have pins that go through the sheet metal and have clips inside.These ones are cast pot metal.DO NOT pry on these.My 64 and 65 have the cast ones,don't know when they switched to stainless,which as I recall are screwed in place.My 72 parts car had this type. _________________ I'm part of the problem. |
c21darrel Samba Member
Joined: January 22, 2009 Posts: 8246 Location: San Dimas
xzener Samba Member
Posted: Mon Jul 10, 2017 4:43 pm Post subject: Re: How to remove the qtr window lower trim pieces? |
The interior had what looked to be threaded nails in high tension areas... I suppose they could look like that if the pan head was covered in paint. But like Darrel said, mine are definitely screws, they can be tightened, thus giving the trim a tighter fit. _________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
